790
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. Bobbie63
    Marshmallow May 22, 2019
    Android450 and SimonRam like this.
  2. U1517851152457
    Eclair May 22, 2019
    dynamicdn likes this.
  3. Bobbie63
    Bobbie63 , May 22, 2019 :
    Nope... still gotta pay for that. I'm hoping next update gives us the free cheese.
    SimonRam likes this.
  4. SimonRam
    Lollipop May 22, 2019
    SimonRam , May 22, 2019 :
    9.0.2 , really?
  5. hany13
    Gingerbread May 22, 2019
    hany13 , May 22, 2019 :
    installed the update using Oxygen updater
    works good for now, took around 12-15 minutes to install but works decent for now, will wait until all background process are done updating and will leave another comment later
    Abhi Dahiya likes this.
  6. SimonRam
    Android450 and Bobbie63 like this.
  7. tasawwur_12q
  8. sidkalpa
    Eclair May 22, 2019
    sidkalpa , May 22, 2019 :
    Can you check if you can download or update apps from the play store?
    hany13 likes this.
  9. zoe_lc
    Cupcake May 22, 2019
  10. hany13
    all my apps updated , works perfectly fine
    flemish_elite likes this.
  11. dhayakrish
  12. Bobbie63
    I'm fine thank you, hope you're fine also.
  13. palc
    Ice Cream Sandwich May 22, 2019
    palc , May 22, 2019 :
    and you suggest we should be sad and frown?
  14. SimonRam
    Yep, all good thanks. A little older, but not much wiser.:)
    Bobbie63 likes this.
  15. cavalry_r3b00t3d
    Froyo May 22, 2019
    cavalry_r3b00t3d , May 22, 2019 :
    can i install this update directly over community beta 2 without any data loss?
  16. palc
    ... it will come as an OTA. go back over to the Community Beta post and read up a bit.
  17. hany13
    i'm not sure i was using oreo before updating
    but it's always recommended by Oneplus to backup your data before going from beta to a full release to avoid problems
  18. palc
    mostly no. but Pie is good. I'm on CB2 for quite a few weeks and it's polished. Though I'd suggest waiting out a month to know of any issues before upgrading if you're that skeptical.
  19. Tzats5
    Eclair May 22, 2019
    Tzats5 , May 22, 2019 :
    Any bugs about the first stable version??
    we will wait for the next fixed update???
  20. Rohan Yuttham
    Rohan Yuttham , May 22, 2019 :
    i was on open beta30 on OnePlus 3T. will i get a stable update or i have to rollback to stable oreo first?
    U1517851152457 likes this.
