791
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. Matthieu Vermeulen
    Froyo Jun 13, 2019
  2. Sampath_Kumar_
    Honeycomb Jun 13, 2019
  3. Zacaa09
    Cupcake Jun 13, 2019
    Zacaa09 , Jun 13, 2019 :
    Thanks! I don't really care about battery because of fast charge. My device is 2 years old and is not the same but fast charge saves me a lot. But it drains the same that the older version, it work for me.
    I'll upgrade when I receive the notification then.
  4. Zacaa09
    pualai likes this.
  5. Arkinos
  6. PriyeshPatil
    Gingerbread Jun 13, 2019
    PriyeshPatil , Jun 13, 2019 :
    Battery and adaptive screen brightness are both on AI so ut takes time to adapt your usage and will be fine after some time of usage! mine works well now!
  7. Mandar_Divekar
    Froyo Jun 13, 2019
    Mandar_Divekar , Jun 13, 2019 :
    I have solved the mystery. Here's how you can get the update in just one step.
    Step: JUST BE PATIENT.
    Got the OTA for OxygenOS 9.0.3.
    Thank you oneplus
  8. Matthieu Vermeulen
    Froyo Jun 13, 2019
    Matthieu Vermeulen , Jun 13, 2019 :
    update completed 45 minutes ago.
    adaptive brightness works, Google lens works, fingerprint scanner and face recognition work at same speed as before.
    Device is very fluid overall.
    very happy with the update so far.
    pualai and PriyeshPatil like this.
  9. Mahbub DU
  10. Jerry Zhang
    Arkinos likes this.
  11. F_Tarun_Goud_RSda
    Eclair Jun 13, 2019
    F_Tarun_Goud_RSda , Jun 13, 2019 :
    Paschfire
    As I already stated within your previous thread, you need to provide more information.
    What OOS version is your device running before attempting to install OOS 9.0.3?
    Stock recovery?
    TWRP?
    Root?
    Also list out the steps you took attempting to flash the update, did you try through Local Upgrade within System Settings? Or flash from recovery?​
    earlier version 8.0.0
    stock rom
    stock recovery
    no root
    no twrp
    I did nothing to get the update. no flashing or anything. i updated it via ota
  12. Kowalsky4
    Eclair Jun 13, 2019
  13. F_Tarun_Goud_RSda
    Eclair Jun 13, 2019
    stock rom
    stock recovery
    no root
    no twrp
    I did nothing to get the update. no flashing or anything. i updated it via ota that ed out earlier today
  14. P1511458180289
  15. Ysfzone
    Froyo Jun 13, 2019
  16. F_Miguel_Ángel_Ruiz_Fr
  17. PascaL_309
    Eclair Jun 13, 2019
    PascaL_309 , Jun 13, 2019 :
    Hi guys! After Pie update, how can I install an apk app?? I can see the app in files, but I can't install it :(
  18. G_Muhammad_Fathedin_pygV
    Froyo Jun 13, 2019
  19. laguiam
    Donut Jun 13, 2019
  20. president99
    president99 , Jun 13, 2019 :
    after pie update phone is getting horrible slow.although i did factory reset.pie isn't smooth like Oreo.phone Boot Time is too late.play store and YouTube app scroll is lagging.even fingeprint response is slow.please fix the problem.will op3 get oxygen os update Future?[e]1f62d[/e][e]1f62d[/e][e]1f62d[/e][e]1f62d[/e]
