784
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. B1514717992919 Eclair Jun 18, 2019
    B1514717992919, Jun 18, 2019 :
    wow .. seems like a very good food for thought for many. If what you are saying is the real thing (getting stabilized in say a week or so) then nothing like it.
    expectations point awesome [e]1f60a[/e] & so true.
  2. Nattz Froyo Jun 18, 2019
    Nattz, Jun 18, 2019 :
    Read about the changes introduced in Pie. Adaptive brightness will not work as in Oreo.
  3. 9346532846 Donut Jun 18, 2019
  4. 9346532846 Donut Jun 18, 2019
  5. NickShades Donut Jun 18, 2019
    NickShades, Jun 18, 2019 :
    Oxygen OS 9.0.3 downloaded and installed for me yesterday.
    LIke all the above, my MMS texting did not work. I looked up new APN settings, and after updating them, my phone completely knocked out internet within itself, and it was a terrible evening at work.
    I managed to backup to existing settings, got back into internet working (reset to default), and now I am in the same problem. HOWEVER, Everytime, I attempt to make a new APN profile for my carrier, the OnePlus3t REFUSES to save it.
    I cannot for the life of me get it to save a new carrier/APN profile. I don't want to go through the same rigamarole I went through earlier, and I also do not want to be without MMS capabilities (as they are absolutely necessary for my job).
    What gives? Why the hell is this happening? Why can I not create a new APN profile?
    This is very disgruntling.
  6. Cervantes Lollipop Moderator Jun 18, 2019
    Cervantes, Jun 18, 2019 :
    Hi
    You should not use old threads
    The update thread is a thread of questions and/or commentary
    Please, You can use the search engine before opening a new thread
    Thread merged
  7. chandralbk21 Cupcake Jun 18, 2019
  8. G_Mizanur_Rahman_munna_S Donut Jun 18, 2019
    G_Mizanur_Rahman_munna_S, Jun 18, 2019 :
    Having to many problem after pie update.
    Example:
    1. Double tap screen wake problem
    2. Battery draining
    3. Phone hang and switched power off. Power button doesn't work after certain time it works.
    4. Clear app button was bottom of the screen, now we have to swipe all app than clear all button shows.
    5. Camera app is slow
    6. We could goto gallary list view from camera view image, now it is not found.
    Otherwise good but please fix this issues.
    Thanks and regards.
  9. Cervantes Lollipop Moderator Jun 18, 2019
    Hi
    Thread merged
  10. Praty_28 Jelly Bean Jun 18, 2019
    Praty_28, Jun 18, 2019 :
    Easiest way to bring your phone back locked bootloader state is by using an unbrick tool. You can also use the standard method of using adb to lock bootloader but considering the previous owner had rooted the device it might as well have twrp installed which will create complications in the process. So im suggesting you use the unbrick tool. You will lose all your data so take a backup of everything.
    Here is the link to the unbrick tool thread. https://www.google.com/amp/s/forum....ick-unbrick-tutorial-oneplus-3t-t3515306/amp/
    Psyphon likes this.
  11. G_Virgilio_Ritzu_HciS Cupcake Jun 18, 2019
    G_Virgilio_Ritzu_HciS, Jun 18, 2019 :
    installation failed. i tred whit the reciving notification and then downloading by myself the rom. bau nothing. is a common problem or just mine?????
  12. Shashank H Gingerbread Jun 18, 2019
    Andrey Plenkin likes this.
  13. ghostofcain Marshmallow Jun 18, 2019
    ghostofcain, Jun 18, 2019 :
    Unlocked bootloader perchance?
  14. ghostofcain Marshmallow Jun 18, 2019
    Why the new thread?, please address issues with a release in the release thread.
  15. Aditya Dange Honeycomb Jun 18, 2019
    Aditya Dange, Jun 18, 2019 :
    Fingerprint as well as face unlock feels slower with Pie update..Any solution to make it snappy as it was with Oreo??
  16. Cervantes Lollipop Moderator Jun 18, 2019
    Hi
    You can read the first post
    Thread merged
  17. G_rajkamal_r._ppcY Cupcake Jun 18, 2019
    G_rajkamal_r._ppcY, Jun 18, 2019 :
    Hi Team,
    After this 3T update the power is draining soon and the local screen goes to night mode automatically. Please fix it or send patches...
  18. Hrushikeshg Cupcake Jun 18, 2019
    Hrushikeshg, Jun 18, 2019 :
    when I upgraded my one plus 3t to android 9 there are lots of issues generated.. the main and first thing is slowness, a lots of slowness occurred after upgrading. please do something
    Andrey Plenkin and arw2007 like this.
  19. ghostofcain Marshmallow Jun 18, 2019
    I assume you've given it the minimum 4-5 charge cycles to optimise?, and then factory reset and waited another 4-5 charge cycles?
    syntek99 likes this.
  20. Hrushikeshg Cupcake Jun 18, 2019
    no.. they said to wipe out cache
