784
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. ghostofcain Marshmallow Jun 18, 2019
    ghostofcain, Jun 18, 2019 :
    That'll certainly cause battery drain.
  2. Hrushikeshg Cupcake Jun 18, 2019
  3. ghostofcain Marshmallow Jun 18, 2019
    Give it 4-5 full charge cycles, after you wiped cache, to re optimise, then if still having issues try a factory reset with a further period of optimisation. Come back if you've still got issues
    syntek99, sandeep21 and Kalyan like this.
  4. T1560835860817 Cupcake Jun 18, 2019
    T1560835860817, Jun 18, 2019 :
    this issue not related to adaptive brightness.its working touc h not working on slider in notification.
  5. G_Alexander_Naidenov_vAL Cupcake Jun 18, 2019
    G_Alexander_Naidenov_vAL, Jun 18, 2019 :
    When I firstly decided to change the brand that I've used for more than 10 years for OnePuls 3t I thought that It was a good decision. But 2,5 years later I found that OP is the same as the other big brands... ruining top hardware with crappy software.
    Now I'm considering other Chinese smartphone brands, looking for longlasting experience!
    What about you?
    Kalyan likes this.
  6. Psyphon Froyo Jun 18, 2019
    Psyphon, Jun 18, 2019 :
    Thanks! I'll give it a try. [e]1f44d[/e]
  7. nin8609 Donut Jun 18, 2019
    nin8609, Jun 18, 2019 :
    Hello, I am a Oneplus 3T user from Mumbai, India. After updating the Oneplus 3T for android Pie the battery starts functioning pathetically bad. the battery drains very fast. without any activity, the screen is turned off and no apps running in the background the battery drained from 15% to 11% in just 4 minutes. with very less activity of opening two apps only one being Whatsapp and google chrome the battery drained from 72% to 50% in just less than 25 minutes. when battery information displayed by the phone than it showed maximum battery consumed in face detection. after disabling face detection mode, no improvement seen in the performance of the battery. kindly resolve the issue at the earliest.
  8. Kalyan Eclair Jun 18, 2019
    Kalyan, Jun 18, 2019 :
    Exactly same feeling.. thinking of Realme 3Pro
  9. Kalyan Eclair Jun 18, 2019
    Try this
  10. abhi1+3 Froyo Jun 18, 2019
  11. Edmund9000 Eclair Jun 18, 2019
    Edmund9000, Jun 18, 2019 :
    oneplus, I amici talking to you.
    you destroyed my OP3T
    I Will not forget this
    If you were not ready for pie in OP3T you couldnt sent any update
  12. Edmund9000 Eclair Jun 18, 2019
  13. ghostofcain Marshmallow Jun 18, 2019
    Instead of spamming the forums with your issues, why not spend a little time reading? Your experience is not typical hence the issues are with your device not the build.
  14. nin8609 Donut Jun 18, 2019
    Kalyan likes this.
  15. ghostofcain Marshmallow Jun 18, 2019
    Post update your device requires at least 3-4 full charge cycles to optimise, if your device has not been through that then please come back when it has.
  16. L1528086816974 Cupcake Jun 18, 2019
  17. Edmund9000 Eclair Jun 18, 2019
    this answer Is not professional
    my mobile was perfect
    After this update to pie it became useless
    Meet@321 likes this.
  18. ghostofcain Marshmallow Jun 18, 2019
  19. E1560866366664 Cupcake Jun 18, 2019
    syntek99 likes this.
  20. panchogd Cupcake Jun 18, 2019
    panchogd, Jun 18, 2019 :
    Hi,
    After updating my phone turned slow. I mainly experience it when I open a new app, usually appears a blue circular arrow for some seconds. I tried to wipe cache, disable animations, change the launcher to nova, etc. It improved just a bit, but the sometimes the lag is exasperating me. I have read several threads (even oneplus 5 or 6), and the only conclusion I got was: factory reset does not solve the issue.
    Is there anything I can do to fix it?
    Many thanks!
    Edmund9000 likes this.
