785
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. Cervantes Lollipop Moderator Jun 18, 2019
    Cervantes, Jun 18, 2019 :
    Hi
    The update thread is a thread of questions and/or commentary
    Please, you can read the first post
    Thread closed
  2. ladyspike Donut Jun 18, 2019
    ladyspike, Jun 18, 2019 :
    Please do and leve the forum!
    syntek99 likes this.
  3. Amanbassan65 Cupcake Jun 18, 2019
    Amanbassan65, Jun 18, 2019 :
    This update is the worst update from last two years of experience..starting with battery it gets fast discharge and take a more than 1hour to charge after software updation..and every software even dialer pad is also getting hang and mobile processor is slow and features of camera is also poor..earlier i need to open camera and after a swipe i can view my last clicked photos but now i need to click on photos icon and i cannot moved to gallery directly from camera earlier it was possible..so i request you please work on this functions and provide a new update so that mobile should work properly...otherwise i need to switch.
  4. Tonyxus Gingerbread Jun 18, 2019
    Tonyxus, Jun 18, 2019 :
    Are you serious! This is insane..
  5. Tonyxus Gingerbread Jun 18, 2019
    The camera update is part of the OS. You have to deal with it. You can use 3rd party camera app if this is not acceptable to your usage style. Battery issue is something you need to wait for couple of days.
  6. govindc27 Donut Jun 18, 2019
    govindc27, Jun 18, 2019 :
    updating got stuck, after downloading the package. showing verifying update package and progress bars are not moving, check for updates button also not working.
  7. ghostofcain Marshmallow Jun 18, 2019
    ghostofcain, Jun 18, 2019 :
    Not in these forums, I assume you've submitted feedback using the appropriate forms?
    The method to revert to Oreo has been covered several times in this very thread.
    It's supposed to work better, but it takes time to adjust to your usage. So not really crazy at all.
  8. Amanbassan65 Cupcake Jun 18, 2019
    What about the apps getting hanged no application working properly ?
  9. Edmund9000 Eclair Jun 18, 2019
    Edmund9000, Jun 18, 2019 :
    thanks for your support as member of this community
  10. ghostofcain Marshmallow Jun 18, 2019
    Many users are reporting no issues, have you considered the issue maybe something to do with YOUR setup?
  11. Amanbassan65 Cupcake Jun 18, 2019
    what kind of setup? using limited apps and having 15gb of internal space
    Edmund9000 likes this.
  12. ghostofcain Marshmallow Jun 18, 2019
    I don't know, without going through your apps minimal or otherwise, whether the apps are all optimised for P. My advice would be try booting into safe mode and see if YOUR issues persist.
  13. Edmund9000 Eclair Jun 18, 2019
    yes, what kind of setup? I don't use either facebook or any other social
  14. Tonyxus Gingerbread Jun 18, 2019
    Many are having no issues and there is nothing to worry about it while the other many are having issues and this is something to worry about so that there is no issue like the other many. Also, if many many are having similar cases then this is a serious issue. There is nothing to do with setup unless the is rooted and has something fancy under the hood.
  15. ghostofcain Marshmallow Jun 18, 2019
    Not all apps are optimised for P, it's entirely possible that one or more of them is misbehaving do your issues persist in safe mode?
    Issues inherent in the ROM ie that OnePlus can fix, should be apparent for all users. Most users who have carried out a clean flash are having very few of these issues, which points to a simple solution for many of you.
  16. Tonyxus Gingerbread Jun 18, 2019
    True that. But what about the same issue with people who have done a clean flash.
  17. ghostofcain Marshmallow Jun 18, 2019
    And what issues exactly are plaguing all the users who've clean flashed the build?
    nombre74 likes this.
  18. G1560873799895 Cupcake Jun 18, 2019
    G1560873799895, Jun 18, 2019 :
    Aftr the update to 9.0.3, my WhatsApp has stopped working kn wifi; need to change to data mode each time to send and receive msgs. Anyone else facing this issue?
  19. Zx7R Cupcake Jun 18, 2019
    Zx7R, Jun 18, 2019 :
    Excellent!
    I have this update for a week now, all works fine, but:
    1. Login with fingerprint sometimes not working at all - I need to click on the power button to wake the phone up.
    2. The lock apps for working in the background constantly - is now hidden to a context menu of the app - very inconvenient.
    3. The disaster - all open apps were one a bit above another, you didn't need to swipe a whole screen for it - very unusable :(.
    Pro - camera looks much nicer now.
  20. Zx7R Cupcake Jun 18, 2019
    For me - sometimes it doesn't seem to work at all, until I wake the phone up by pressing on the power button.
    Tonyxus likes this.
