790
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. president99
    Froyo May 22, 2019
  2. Justin Yap
    Gingerbread May 22, 2019
    Justin Yap , May 22, 2019 :
    RM4199 for 12gb version, sad ........
    gunnersteoh likes this.
  3. abhi24
  4. abhi24
    abhi24 , May 22, 2019 :
    bro.
  5. _chetan_chauhan
  6. G_claudio_guglielmo_ihEF
    Cupcake May 22, 2019
    G_claudio_guglielmo_ihEF , May 22, 2019 :
    I come from the stable version of Oreo 8.0.1 and today I made the update to Android Pie. I mount 2 SIM in the 3t and I notice that the parallel apps (WhatsApp) go in crash. solutions ??? the same happened with android Oreo and the solution was contactsprovider.apk but on Android Pie I can't find a solution
  7. abhi24
    what's the difference between incremental and full update ??
  8. _chetan_chauhan
  9. abhi24
    and regarding the camera thing. will they replace it for free now as well ??
  10. _chetan_chauhan
    _chetan_chauhan , May 22, 2019 :
    full update is generally for rooted devices bro!
  11. pumlianlal
    Donut May 22, 2019
    pumlianlal , May 22, 2019 :
    am not rooted but use to update in full update.. any problem bro.
    abhi24 likes this.
  12. _chetan_chauhan
    yes they will, one of my friend was having same camera focus issues! they just changed the part for free even after 2 years of purchase!
  13. sidkalpa
    Eclair May 22, 2019
    sidkalpa , May 22, 2019 :
    No. The 1616mb update is the same.
  14. rblaker
    Eclair May 22, 2019
  15. pumlianlal
    Donut May 22, 2019
  16. _chetan_chauhan
    not at all, as you have not updated your's with community builds.
  17. _chetan_chauhan
    i prefer to do clean update everytime with big updates!
    backing up all your imp data, restting & wiping the storage, & than updating it! i have never faced any issues after that! though its tiresome for some people with lots of data!
    Kunlan likes this.
  18. _chetan_chauhan
    try wiping cache under recovery once, it might help solve the issue.
  19. yiddyuk
    yiddyuk , May 22, 2019 :
    I'm on unlocked bootloader so I'll need to use twrp to install without wiping date so to confirm the steps are.
    1. Install Twrp.
    2. Boot into Twrp & install full Official 9.0 & clear cache.
    3. Reflash Twrp.
    4. To keep Twrp reboot into recovery or just reboot to system for stock recovery.
    Will I encounter encryption issues?
    Did I miss anything?
    Do I need a modified Twrp? (if yes which one)
    @astralbee
    Starcommander likes this.
  20. _chetan_chauhan
    Gingerbread May 23, 2019
    _chetan_chauhan , May 23, 2019 :
    for those who are on community beta builds, you need to enable 'advance mode' under settings tab in 'oxygen updater' app!
