790
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. Umairq
    Cupcake May 23, 2019
  2. abhi24
    Gingerbread May 23, 2019
    abhi24 , May 23, 2019 :
    i am going to update my device now using oxygen updater. should I do full update or Incremental update ??
  3. Sadam_H
    Eclair May 23, 2019
  4. abhi24
    1.6 GB.
  5. yiddyuk
  6. Oomaar
    Oomaar , May 23, 2019 :
    catalinus
    If upgraded to Pie and things go badly will it be possible to revert to Oreo (even if involves a complete factory reset) ?​
    Yes, all you have to do is to flash the previous version.
  7. _chetan_chauhan
    _chetan_chauhan , May 23, 2019 :
    sorry bro, i might not be the right person to answer that, as i have no practical knowledge of twrp/side load! please wait, someone might help you out with your doubts.
  8. abhi24
  9. Umairq
    Umairq , May 23, 2019 :
    should we wait for another Stable update.,? are we good to go and update.?
  10. _chetan_chauhan
    if you are on community beta builds, it will show no updates until & unless you switch to 'advance mode' in settings! you would get the update after that! its 1617 mb!
  11. abhi24
    no im on oreo now.
  12. Wasimk172
    Wasimk172 , May 23, 2019 :
    where is the link for update. And if there, how to update
  13. alexander420
  14. eera5607xx
    eera5607xx , May 23, 2019 :
    Hi everyone. Is there a way to start from zero instead of updating over the previous version? My phone is not rooted.
  15. _chetan_chauhan
    then it might be under incremental updates! just go beyond that page, incremental/full update, you'll find latest update for your device bro.
  16. Umairq
    r u serious. does your hardware even support 5g.?
    whhhhaaaattttttt
    Oomaar and _chetan_chauhan like this.
  17. AlexanderMK
    Eclair May 23, 2019
    AlexanderMK , May 23, 2019 :
    It's been a long time since i've been here ... It's awesome that we receive this update on the 3/3T devices. Thanks for the efford OP team. Surely my next device will be again from OnePlus.
    Also, updated my 3T device with the Oxygen Updater from the Play Store, everything went okay. Also don't forget to wipe out the cache after the install.
  18. sathiishh
  19. abhi24
    when im putting it to full update , its in black colour and when I put it to incremental update it is in green color. so it's saying that i should do a Incremental update ??
  20. _chetan_chauhan
