784
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. ghostofcain Marshmallow Jun 26, 2019
    ghostofcain, Jun 26, 2019 :
    And what OS version are you currently running.
  2. Ankitbhat12345 Jelly Bean Jun 26, 2019
  3. Ysfzone Froyo Jun 26, 2019
  4. Muscle.man007 Cupcake Jun 26, 2019
    Muscle.man007, Jun 26, 2019 :
    For some reason the range in wifi detection is decreased.
    No smile detection in front facing camera.
    No cache cleaning from the setting for all apps at the same time.
    Features should be added in updates rather than be removed.
    Isn't that how it usually works?
  5. M1523000660368 Cupcake Jun 26, 2019
  6. tamilmani_t Eclair Jun 26, 2019
    tamilmani_t, Jun 26, 2019 :
    I would like to thank the developers over there for their great work in baking the Pie for over 2 years old device.
    The UI and other stock customization have come up very well and as usual the OS is fluid.
    Other notable key features include customized gaming mode, customized DND mode.
    But there are few cons that I would like to mention though:
    1. Battery is relatively draining a lot in Pie when compared to the latest stable Oreo release.
    2. Phone often gets warmer while using apps from standby. Temperature is low when in standby. This was not the case in Oreo.
    3. "Mobile network standby" consumes majority of the battery followed by "Android system".
    4. Sometimes the screen is blank when an incoming call is received, forcing to press the power key to identify the caller.
    I hope above mentioned cons will be fixed in the future updates.
    Let's hope for the Pie to be more tastier.
    P.S:
    1.I did a factory reset after upgrading the OS.
    2.Cleared the cache before and after up gradation.
    acsubrat and alexbitos like this.
  7. M1523000660368 Cupcake Jun 26, 2019
    M1523000660368, Jun 26, 2019 :
    i still use oreo.. no update for me.. so u mean i shudnt update yet?
    alexbitos likes this.
  8. tamilmani_t Eclair Jun 26, 2019
    You can update it if you receive the OTA.
    But if you want to get the fix, probably you might need to wait for a month or so.
  9. Ishant_mahajan Eclair Jun 26, 2019
    Ishant_mahajan, Jun 26, 2019 :
    any ideas about that alarm clock bug?
    let's hope they fix things up with a new update!!
  10. G_manohar_taide_PLlr Cupcake Jun 26, 2019
    G_manohar_taide_PLlr, Jun 26, 2019 :
    I received the update & working well but battery draining is fast....
    In previous OS in my regular use 50 % battery utilisation was observed within 12 hrs...
    However due to new OS battery drains
    90 % within 12 hrs....
    Please suggest solution....
  11. Praty_28 Jelly Bean Jun 26, 2019
    Praty_28, Jun 26, 2019 :
    I have not heard about an alarm bug. What is it exactly?
  12. Praty_28 Jelly Bean Jun 26, 2019
    Its because of mobile network standby many users who use mobile data are affected by this.
  13. bharat9848 Cupcake Jun 26, 2019
    bharat9848, Jun 26, 2019 :
    How to revert it. My hotspot is not allowing internet access to other devices. Thanks in advance. I am blocked. Please help
  14. Ishant_mahajan Eclair Jun 26, 2019
    if u would read my 1st post on pg 277 #5540 I have explained the issue
  15. GNex Cupcake Jun 26, 2019
    GNex, Jun 26, 2019 :
    A few features from Android 8 are missing including change of location services to device only, battery saving, high accuracy. will this come again in a future update?
    Is it possible to move the clock on the status bar back to the right site?
    Also battery life is really poor. When I bought my 3T in the end of 2016 I could hit 7 hours of screen on time. now it is below 4 hours. Of course there is battery degradation, but now the battery sometimes struggles to hold through the day.
  16. ghostofcain Marshmallow Jun 26, 2019
    And what pray tell did the OP of the beta thread tell you prior to installation? Go back there re-read the OP and in no time at all you'll have a toasty new clean install of Pie
  17. A1538256954698 Cupcake Jun 26, 2019
    A1538256954698, Jun 26, 2019 :
    better dnt update belive me u will regrett it
  18. M1523000660368 Cupcake Jun 26, 2019
    better i wait for the fix then.. thank u
  19. M1523000660368 Cupcake Jun 26, 2019
    sure.. i shall wait for the fix.. and how would i knw if the fix update comes?
  20. asb0410 Gingerbread Jun 26, 2019
