790
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. asb0410
    Gingerbread Jun 26, 2019
    asb0410 , Jun 26, 2019 :
    Yes, I understand. But I haven't any save button.
  2. mikica023
    Honeycomb Jun 26, 2019
    mikica023 , Jun 26, 2019 :
    There is a bug. Press to select what you want and then tap on the screen (or swipe down). Then you will see save.
  3. asb0410
    mikica023
    There is a bug. Press to select what you want and then tap on the screen (or swipe down). Then you will see save.​
    Thank you) I found a solution. I changed a scale of the picture on my screen. If selected scale is big we can't see a button. But, when I changed a scale to default, I could see a half of the button)
    Maybe it also depends on system language.
  4. B1535831885820
    Cupcake Jun 26, 2019
    B1535831885820 , Jun 26, 2019 :
    My phone sometime doesn't unlock as i press the unlock/lock button. This is really troubling. I tried wallpaper change, launcher change, battery optimization disable etc etc. Any fix ?
  5. Y4LI7_C0RR34
    Donut Jun 26, 2019
    Y4LI7_C0RR34 , Jun 26, 2019 :
    So much disappointed about OP!!! I think they don't want to invest more time (money) on the OP3/T model (users) anymore. They promised PIE to give a good impression on the web, the social network... Then they realized that they will not be able to manage how difficult is to make an old device up to date and because there are not oblige to provide it to us, they give an unfinished OS. And let people by a New one after getting board about it. There are not the OP1 Spirit anymore there are like all Major's now. So ok I pass my way to Major's with what They propose me. ( after pie update I charge it 3 time per day.) 1 month use.
    Kowalsky4 and m.parvage like this.
  6. Blue-agila
    Ice Cream Sandwich Jun 26, 2019
    Blue-agila , Jun 26, 2019 :
    Not on open beta by any chance?
    Auristic likes this.
  7. Paschfire
    KitKat Jun 27, 2019
    Paschfire , Jun 27, 2019 :
    So clearly the battery has worn out after 2+yrs of usage, get it replaced at an authorized OnePlus service center.
  8. Praty_28
    KitKat Jun 27, 2019
    Praty_28 , Jun 27, 2019 :
    No clock bug for me. I haven't updated to latest pie build i am still on the first community beta so maybe i have an older version of clock app.
  9. d.a.gribov
    Cupcake Jun 27, 2019
    d.a.gribov , Jun 27, 2019 :
    [kinda quote]
    jeaneco
    Help please,
    Since I have installed the new Android Pie my phone keeps turning off by itself every night on flight mode and fully charged. When I turn it on in the morning the battery is on 37%. The scheduled power off is turned off
    Thank you
    d.a.gribov
    Try to disable Adaptive Battery
    jeaneco
    I did it and I think everything is now working. Fingers crossed it won't turn off again. once again thank you for ur suggestion.
    [/kinda quote]
    In case it didn't help, I think I finally found a solution!
    Try disabling "Sleep standby optimization" option in Battery / Battery optimization / (menu) Advanced optimization. Actually, try disabling everything on that page.
    This one helped me, and I hope it will help others.
    GameOver00X and jeaneco like this.
  10. O1520688061571
    O1520688061571 , Jun 27, 2019 :
    go to recovery mode and clear cache you will get update
  11. PTuT
    Jelly Bean Jun 27, 2019
    PTuT , Jun 27, 2019 :
    Other option is to move to custom ROMs.
  12. 9900099
    9900099 , Jun 27, 2019 :
    Well 3 thing's Mendatery after Update.
    1. Format The Phone Even The Storage.
    2. As Soon As Phone Starts Do the things which are Given In Battery Saver Thread.
    3. Then Go To Battery In Settings and Stop The (Adaptive Battery).
    4. Install (Win X Launcher).
    5. Then Settings--Apps And Notification--Win X Launcher--Data Usage-- Disable Data Usage and Wifi Usage.
    My Battery Life Better Than Oreo And Fast Charging Same As Oreo
    Enjoy!!
    Y4LI7_C0RR34 likes this.
  13. PTuT
    So many people report sudden increase in poor battery performance after upgrade. It cannot be all batteries suddenly worn out to the point of replacement. That smell fishy to me. I think OP engineers should closely look at the issue as it seems more like a problem with ROM itself.
    nabsrai and Kx1707 like this.
  14. PTuT
    Right way, 1st point requires something that should not be normally used for system upgrade. That's why it is upgrade, you should be able to take phone and get new system without need to loose your stuff...just like it was done in all previous OOS upgrades of our phones.
  15. OPO OOS lover
    OPO OOS lover , Jun 27, 2019 :
    Hi @Cosmos_NT I wanted to ask you one question-
    Recently I had searched for all OnePlus 7 features in APK mirror and I found all except Fnatic Mode
    Why isn't Fnatic Mode APK not available if these features are hardware independent?
  16. Nattz
    Froyo Jun 27, 2019
    Nattz , Jun 27, 2019 :
    It's not a bug. Pie is now sensitive to any alarm; it includes alarm that any app, not just clock, can produce. I. E. If you have tasker, disable reliable alarms. If you do not use tasker, think of any other app that might produce alarm. Alternatively, just kill the app one by one until you manage to find it.
    Ishant_mahajan and PTuT like this.
  17. Yash Narain
    Gingerbread Jun 27, 2019
    Yash Narain , Jun 27, 2019 :
    Do Not Disturb mode is not working properly...when I select the option "No sound from Notification" even then the sound comes when notification arrives. Any solution ?
  18. Anand_Nair
    Anand_Nair , Jun 27, 2019 :
    Due to heavy battery drains .. i decided to rollback to Oreo update.
    Does locally downgrading clears all my data in the internal storage?
    S1543657713145 likes this.
  19. ghostofcain
    Marshmallow Jun 27, 2019
    ghostofcain , Jun 27, 2019 :
    He won't, he's an open beta user.
    Nope you need to do that yourself, unless that is you wish to be beset by a multitude of issues.
  20. Ishant_mahajan
    Eclair Jun 27, 2019
    Ishant_mahajan , Jun 27, 2019 :
    thank you!!it worked an app was using those alarms
