791
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. G_S_Mohsen_Houshyar_FgPB
    Froyo Jun 29, 2019
    G_S_Mohsen_Houshyar_FgPB , Jun 29, 2019 :
    with OP3T hardware you can except OnePlus team to keep its up to date
    only hardware feature like camera resolution and finger scan under display can not be added.
    but OP3T's hardware is better than lot of new devices.
  2. priyanshugupta9
    Gingerbread Jun 29, 2019
  3. Darekb81
    Honeycomb Jun 29, 2019
  4. Deactivated User
    Jun 29, 2019
    G_Sami_U_aMgj likes this.
  5. groove96
    Cupcake Jun 29, 2019
  6. ngpbay
    Froyo Jun 29, 2019
  7. Darekb81
  8. smoode002
    Eclair Jun 29, 2019
    smoode002 , Jun 29, 2019 :
    Just downloaded the update through using NordVPN using the server from Frankfurt Germany. The update took noticeably longer than the last two to install. Awaiting for update to settle before testing. Screenshot_20190629-143001.jpg
  9. G_Subrat_Nayak_eMEB
    Froyo Jun 29, 2019
  10. xythiii
    Ice Cream Sandwich Jun 29, 2019
  11. Abhi Dahiya
    Abhi Dahiya , Jun 29, 2019 :
    Guys do tell if any of these issues are fixed or not after OOS 5.0.4 update >
    1. "Mobile network stand-by" battery drain
    2. Lower earpiece in call volume compared to Oreo and Nougat
    3. In call earpiece sound not as clear and crisp as earlier
    4. Unavailability of "HQ" mode in camera
    5. Bad RAM management
  12. beast_sunny
    beast_sunny , Jun 29, 2019 :
    any improvement?
  13. Lourdes Muñoz
    Cupcake Jun 30, 2019
  14. RubyxD
    RubyxD , Jun 30, 2019 :
    when I upgrade to android 9.0 gives me error, it may be because I have the bootloader unlocked?
  15. Paschfire
    KitKat Jun 30, 2019
    Paschfire , Jun 30, 2019 :
    Are you currently running OOS 5.0.8? Then, yes.
    RubyxD likes this.
  16. Kiran.a.joseph
    Jelly Bean Jun 30, 2019
    Kiran.a.joseph , Jun 30, 2019 :
    I also got the notification to update to 9.0.4
  17. RubyxD
    Thanks bro[e]1f609[/e]
  18. smoode002
    Eclair Jun 30, 2019
    smoode002 , Jun 30, 2019 :
    So far it appears that performance has definitely improved on 9.0.4. Battery drain is much better than before with adaptive Battery enabled. Screenshot_20190629-211524.jpg Screenshot_20190629-211530.jpg
  19. Prahallad
    Froyo Jun 30, 2019
  20. Fhdshahzad
    Gingerbread Jun 30, 2019
    Fhdshahzad , Jun 30, 2019 :
    How did you get 9.0.4, please share the performance status
