791
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. G_Mojtaba_Dehghan_MWFH
    Cupcake Jun 30, 2019
    niallktin likes this.
  2. Darekb81
    Honeycomb Jun 30, 2019
  3. Pratham_38
    Pratham_38 , Jun 30, 2019 :
    some improvement , not much , Oreo experience was still much much better .
  4. Darekb81
    Darekb81 , Jun 30, 2019 :
    Have you hard reset your phone from recovery deleting all files and data? If not, this is the most probable solution for all your problems with the phone.
    J1560673642290 likes this.
  5. J1560673642290
    Donut Jun 30, 2019
    J1560673642290 , Jun 30, 2019 :
    If you didn't factory reset then you can't share experience. It is mandatory.
    Auto brightness is fixed
    Low volume in earpiece somehow became better.
    Give the Rom some time, at least 48 hours or one full cycle charge then report an issue.
    Darekb81 likes this.
  6. Pratham_38
    by "this" , you mean flashing a custom ROM ? and , if it's not too much trouble , can you share a link as to how to hard reset from recovery ? if it's a hassle I'll try and look for it myself .
  7. Darekb81
  8. G_Laci_Balogh_vUNs
    G_Laci_Balogh_vUNs , Jun 30, 2019 :
    since I have PIE on my OP3 the battery lasts about 6-7 hours. , and few apps are not starting or freeze, phone gets hot, screen not turning, cameras not working and many other things just rubbish. I had to buy a new phone as this one is useless now. thank you guys at OnePlus....
  9. Darekb81
    Thank you cupcake for this excellent review of the new update. Very useful. Of course you did all the recommended steps on how to solve those bugs. Hint: hard reset.
  10. G_Laci_Balogh_vUNs
    I have done that. did not work "cupcake"! I even have done more than that. Still have the issues. "Cupcake"! Thank you for the wise advise CUPCAKE!!!
  11. Darekb81
    What can you do more than HARD reset? CUPCAKE!
  12. G_Laci_Balogh_vUNs
    restore to android 6 factory settings. fix filesystem, fix partitions....etc. ?!
  13. Darekb81
    :tearsofjoy: no wonder why you have those problem. Just clean flash new system.
  14. ghostofcain
    Marshmallow Jun 30, 2019
    ghostofcain , Jun 30, 2019 :
    If you can see the problem from your logs, cant you fix it? Or just maybe it's a bigger problem than you appreciate and even with the logs from your device the solution isn't yet obvious.
    BTW OnePlus aren't the only OEM struggling with standby battery drain in Pie.
  15. T1560956592516
  16. Praty_28
    KitKat Jul 1, 2019
    Praty_28 , Jul 1, 2019 :
    I did that aswell. All we can do is wait. I'd be pissed aswell if i used mobile data all the time. Luckily i have wifi access for most of the time.
  17. panda_007
    Donut Jul 2, 2019
    panda_007 , Jul 2, 2019 :
    Guys, I just got a reply from one of the members of OnePlus, they are going to release a patch for OnePlus 3/3T. Let's hope this patch will fix our problems, if not all, at least to some extent.
  18. ambilad
    Cupcake Jul 2, 2019
    ambilad , Jul 2, 2019 :
    After PIE update my 3T is very slow. Very sad, have to do something immediately.
  19. Sagar_Bajad
    Cupcake Jul 2, 2019
    Sagar_Bajad , Jul 2, 2019 :
    BAD update, Phone became very slow, all the sluggishness, after call hung up call duration still displayed for few seconds, unnecessary screenshots,etc. Kindly get us the fix ASAP.
  20. R Krishnan
    Cupcake Jul 2, 2019
    R Krishnan , Jul 2, 2019 :
    I am taking back what I had posted earlier about the update, now only I am facing the problems. it seems that my 3 T is behaving of it's own after the update to pie. it's sleeps itself. and now it keeps on restarting with out booting, The pie update is pathatick...
    Till know I was very much satisfied with 1+ product
    with this update I just lost it.....
