790
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. sandipbhurse
    Eclair May 23, 2019
    sandipbhurse , May 23, 2019 :
    Is parallel app has been continued in Oxygen OS pie version , can I run 2 what's app simultaneously..
  2. RubenGS
    Cupcake May 23, 2019
    RubenGS , May 23, 2019 :
    How can i do that?
  3. Cosmos_NT
    Jelly Bean May 23, 2019
    Cosmos_NT , May 23, 2019 :
    Read Oxygen OS Updater, it clearly mentioned that OnePlus never fixed that bug.
  4. Cosmos_NT
    Bug reports are already done by many users, it's not like they will solve it by tomorrow and again release an update, it will take some time.
    Apps that are exclusive for OP7 will be supported by 5/5T/6/6T in Pie but it isn't confirmed when. So if they solve those problem for 5/5T it should work for 3/3T but for now it isn't.
  5. oneplususer23
    Eclair May 23, 2019
  6. vijayanaveen
    Gingerbread May 23, 2019
    vijayanaveen , May 23, 2019 :
    My suggestion to all please wait don't try using any link because so many Link added about Android 9 stable version Even officially didn't mentioned about Build id if they mentioned we can identify the stable version while download using the link now we all totally confused Soon we will get clear once received OTA update.
    Rogerio_Coutinho likes this.
  7. straightbender
    Eclair May 23, 2019
    straightbender , May 23, 2019 :
    TWRP > Wipe > Swipe to Factory Reset. That'll do.
  8. Meet@321
    Honeycomb May 23, 2019
    Meet@321 , May 23, 2019 :
    I did report..... Maybe you should too.... The more the reports for it the better we get it
    OPO OOS lover likes this.
  9. Rogerio_Coutinho
    Rogerio_Coutinho , May 23, 2019 :
    A few more questions.
    As I am in Beta39, when I install the update, it goes to normal version.
    Before I upgrade do I need to reset the device?
    Doing this update will I lose any data that is on the device?
  10. shobuddy
    Donut May 23, 2019
    shobuddy , May 23, 2019 :
    I have an unlocked bootloader but no root. Will I get my data wiped clean if I wait till I get OTA notification?
  11. straightbender
    Eclair May 23, 2019
    As long as your bootloader is locked you don't need to wipe anything. But might as well do a back up, just in case.
  12. G_Emmanuel_Geinoz_DCab
    G_Emmanuel_Geinoz_DCab , May 23, 2019 :
    hello,
    As specified in the help of AdAway you should try to change the target host file:
    It worked for me
  13. straightbender
    Eclair May 23, 2019
    Yes dear, you need to do a factory reset with bootloader unlocked.
    shobuddy and Rogerio_Coutinho like this.
  14. G_MD_SIRAJ_HASMI_gJKp
    Donut May 23, 2019
  15. Rogerio_Coutinho
    But using the Oxygen Updater application, can we upgrade?
  16. Raj Parsana
    Donut May 23, 2019
  17. abhi24
    abhi24 , May 23, 2019 :
    guys don't update your phone via oxygen updater. it has bugs, my friends have done and they are facing issues. wait for the OTA. just think pie has not been released yet.
  18. abhi24
    dont do that. too many bugs.
  19. rgarzamarcos
    rgarzamarcos , May 23, 2019 :
    ok, please tell me if I am wrong here.
    I have a unlocked bootloader so...
    1. if I try tu update using the oxigen updater It will fail
    2. if I re-lock my bootloader I'll wipe my phone
    3. if I wait until the OTA via the settings menu to show the update everything will be fine
  20. Ysfzone
    Froyo May 23, 2019
    Ysfzone , May 23, 2019 :
    I FOUND A NEW BUG
    Sometimes on incoming call the call ui crach and the phone freeze at all.. just black screen and ringing..
    P1544699139753 likes this.
