791
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. G_Thomas_S_PyvV
    Honeycomb May 23, 2019
    G_Thomas_S_PyvV , May 23, 2019 :
    Stop asking when you'll get the update, no one will answer to you.
    And if you're in a hurry (like I was), just use Oxygen Updater.
    If you prefer to wait for OTA (which will do the exact same thing), shut up and wait
    TheP4infvlWolf and stanciupaul like this.
  2. ddrum2000
    Cupcake May 23, 2019
    ddrum2000 , May 23, 2019 :
    So as a follow up, would the following procedure be have the same or different flaws?
    1 - Full nandroid backup
    2 - Factory reset and then flash 9.0.2 with unlocked bootloader
    3 - restore Data partition from nandroid (so I don't have to spend hours setting up my phone again)
    4 - flash magisk
    Good to go?
  3. G_Surya_Tail_emkS
  4. shobuddy
    Donut May 23, 2019
    shobuddy , May 23, 2019 :
    Unlocked bootloader folks are having the issue with stock recovery as well, not just TWRP.
  5. G_Rodrigo_Gomes_TrjG
  6. tiagofcnmoreira
    tiagofcnmoreira , May 23, 2019 :
    I can confirm this as well!
    Whatsapp Parallel is always crashing... It didn't happen on Community Build 1 and 2.
    I updated from CB2.
    I remember this also happened I believe in the first Oreo version.
  7. MercuryMat
    Froyo May 23, 2019
    MercuryMat , May 23, 2019 :
    Hi!
    The build is very nice and works perfectly. very stable. My OP3 is very responsive and it is great to have such support for a product that is old but has been working perfectly for 3 years now. clap clap OnePlus.
    BUT...maybe someone already posted this, I cannot see the Bluetooth icon in the status bar...is this a "feature" of Android Pie or is a bug?
    The icon appears when Android Auto is active...
    Anyone with this problem?
  8. Bloodyme
    Eclair May 23, 2019
    Bloodyme , May 23, 2019 :
    I'm with Open Beta 39 version (Oreo). Will I receive this update by OTA? Also have bootloader unlocked.
  9. ImmacR
    Eclair May 23, 2019
    ImmacR , May 23, 2019 :
    Finally!!! That pie baked too long but thanks a bunch for supporting an old device more than 2yrs after its release. Marshmallow [e]27a1[/e]️ Nougat [e]27a1[/e]️ Oreo [e]27a1[/e]️ Pie. I'm excited!
    Never Settle‼️
  10. ImmacR
    Eclair May 23, 2019
    the oneplus 3t buttons are under rated. this is one of the reasons it will take me awhile upgrading my fone. I can't deal with the on screen software buttons[e]1f601[/e]
    rmkimathi likes this.
  11. G_Steve_uMYx
    Froyo May 23, 2019
    G_Steve_uMYx , May 23, 2019 :
    No you don't!!!
    Thabet.Azzawi and Nuguns like this.
  12. ImmacR
    Eclair May 23, 2019
    there's no need to downgrade. it's normal for battery drain to occur after a software update. it will take the fone about 2 or 3 charge cycles for the battery to normalise and operating system to stabilise. that's roughly 2-3 days. be patient.
  13. iqbalanis
    Gingerbread May 23, 2019
    iqbalanis , May 23, 2019 :
    obviously they will say that, how can they give assurance regarding files from external sources.
    But its common sense for some people (except you) to know which source is reliable and which is not.
  14. F_Farid_Kamal_OROR
  15. F_Farid_Kamal_OROR
  16. C1547919677037
  17. sammerasker
    Ice Cream Sandwich May 23, 2019
    sammerasker , May 23, 2019 :
    I can't comment on that unless I know exactly how did they flashed and more details, but o doubt of they unlocked already on beta (and they done it right, because the beta required locked bootloader) they shouldn't have issues.
    My point is, people who unlock boatloader should know at least a little more than others.
    I'll try to read past comments and see what issues unlocked bootloader have with official recover...if you have something specific please share it.
    That said, the following is most probably what solve such issue
    OxygenOS 9.0.2 based on Android PIE for OnePlus 3 & OnePlus 3T
  18. B1515743801284
  19. Ashutosh B. Rajan
    Eclair May 23, 2019
  20. Kx1707
    Gingerbread May 24, 2019
    Kx1707 , May 24, 2019 :
    Hi community,
    Could you please share your experience using this stable build and how did you install it (i.e. OTA vs Oxygen Updater)?
    Your feedback is highly appreciated.
    Cheers
    anirudhmathur007 likes this.
