791
OxygenOS 9.0.2 (9.0.3) based on Android PIE for OnePlus 3 & OnePlus 3T
  1. Aru4u
    Eclair May 25, 2019
    Aru4u , May 25, 2019 :
    I am in CB2 from India. So far I have not received update even with Oxygen Updater. Is there any other way to do it ?
  2. karthik oneplus
    Ice Cream Sandwich May 25, 2019
    karthik oneplus , May 25, 2019 :
    Haha well said..
    Half the community questions were filled with
    "When is pie coming to 3/3t "
  3. karthik oneplus
    It is not. There would be many system files of previous os which might clash with new one in addition to that apps compatibility also would come into affect so even if you call customer care they would first ask you to factory reset and then bring to service center.
  4. Meet@321
    Honeycomb May 25, 2019
  5. elanglois
    Lollipop May 25, 2019
    elanglois , May 25, 2019 :
    Stop doing that! It is VERY rare that clearing your Dalvik cache will fix anything. If you get multiple apps all crashing on start-up, reboot to recovery and clear it then. Otherwise, you are just sabotaging your phone.
    If clearing caches was necessary, then the update script in the ROM ZIP would have already done so!
  6. 7873889339
    Donut May 25, 2019
  7. tarunkaundar
    Cupcake May 25, 2019
  8. elanglois
    When will people learn that SOT is meaningless? If you open your phone right off the charger and keep the screen on all day without using it, you'll get an amazing SOT.
    Keep the phone in your pocket for 2 days and it will last 2 days with very little SOT. Use your phone for gaming uses more power than just playing music or texting. And a poor signal causes a much higher drain a good signal since the phone will be searching for a better signal.
    SOT is useless.
  9. camohan
    Moderator Moderator May 25, 2019
    camohan , May 25, 2019 :
    Thread merged. You can continue to discuss in update thread.
    Logic says new Android version requires some charging cycle to settle down.
    Jhevonn likes this.
  10. Cosmos_NT
    KitKat May 25, 2019
    Cosmos_NT , May 25, 2019 :
    Meanwhile *OnePlus 3/3T* : My watch has ended, I'm not the rightful heir of the 7 kingdom, and I'm OnePlus 3/3T *Sanpp*
    All of the above means it's over, may we get bug fixed because the announcement like the pie Update clearly is on the edge to banish 5/5T when they get Q update.
    Moreover, those features will be highly unlikely embedded into OOS, meaning extraction of apk might not work as it should be.
    Don't expect a device with IMX 298, SD 820/1, Non Turbo Boosted, Non Liquid Cooled, Smaller Battery, Old style H/W Buttons, Physical Fingerprint scanner, Non water and dust resistance, No Dolby atmos, No Dual camera (or triple), No withstand with futuristic technology that will out last every single aspect of it to perform those task, it is just one of the Incredibly Engineered Masterpiece that has gone through and survived 4 Generation of Major System Upgrades From Marshmallow to Pie with time and Providing almost all Softwares until hardware limited it, there's no more official release that's gonna happen, accept it and wait for OP7 if 7Pro is too high and you can't get rid of OOS and OP features.
    OPO OOS lover likes this.
  11. Cosmos_NT
    KitKat May 25, 2019
    Wait a week, and you'd need to manually do it for sometime, that's why is has name adaptive.
  12. Cosmos_NT
    KitKat May 25, 2019
    Even MKBHD the YouTuber gets 4 hr on OP7 because it has 90Hz panel refresh rate and QHD+ resolution, get it over with this is best with maximum usage, using 4/5G will drain battery like leaking bottle.
    _chetan_chauhan and Meet@321 like this.
  13. Rachitshah1201
    Gingerbread May 25, 2019
    Rachitshah1201 , May 25, 2019 :
    it's not showing on my system update I am yet using 5.0.8
  14. avinash_verma
    avinash_verma , May 25, 2019 :
    after pie update when internet data off and using wifi after sometime check my data who was consumed.
    it's a bug
  15. Meet@321
    Meet@321 , May 25, 2019 :
    And what about the caller identification feature that ONEPLUS promised in India with pie ?? There's not even a mention of it !!
  16. avinash_verma
  17. avinash_verma
  18. avinash_verma
    net data off used wifi and then check data will be consumption
  19. G_lovepreet_muker_ipzC
    Froyo May 25, 2019
  20. F_Arun_Indhu_Kv_XimN
