685
OxygenOS 9.0.2 OTA for OnePlus 6
  1. H1539441691174
    Cupcake Nov 3, 2018
  2. willverduzco
    Cupcake Nov 3, 2018
    willverduzco , Nov 3, 2018 :
    Unclescrooge - Thank you so much for the reply and suggestion. I tried that, but unfortunately I still do not have access to the new gestures.
    Are you on an A6003 device, and do they work properly for you? Also can you check to see if your build number is the same from the pic in my previous post? Thanks again so much for your help.
    H1539441691174 likes this.
  3. P1535459137139
    Donut Nov 3, 2018
  4. P1535459137139
    Donut Nov 3, 2018
  5. H1539441691174
    Cupcake Nov 3, 2018
  6. Dummyxl
    Froyo Nov 3, 2018
    Dummyxl , Nov 3, 2018 :
    I'm sorry oneplus but The new 9.0.2 update have a lot of bugs on my device! One day of beta testing isn't enough it seems.
    1. When using an app the white X for close apps pops up spontaneously. (and with that hides the keyboard you are using at that moment.) i think typing triggers the structure
    2. The animation feels a bit sluggish and also sometimes a bit buggy.
    3. When using the phone horizontal the structures do not work.
    4. Apps spontaneously start or close.
    Maybe i need to reset my device after this update. More people have this?
    Pirati81 likes this.
  7. BobbyXY
    Cupcake Nov 3, 2018
    BobbyXY , Nov 3, 2018 :
    I haven't got the 9.0.2 update . ? ! !!! should I wait a few days !?
  8. Unclescrooge
    Froyo Nov 3, 2018
    Unclescrooge , Nov 3, 2018 :
    Well Mine is A6000 and so the build number is A6000_22_181026 instead of A6003_22_181026.
    For me gesture navigation are working perfectly.
    You could try force stopping your oneplus launcher after clearing its cache and data and if that too doesn't help then you could try wiping the cache using recovery.
  9. vamsi_krishna440
    Froyo Nov 3, 2018
  10. Unclescrooge
    Froyo Nov 3, 2018
    I am having this issue as well. A team member from Oneplus's Bug Hunter team has asked me to record the video when it happens but you really don't know when it gonna happen next so it is hard to record the video for that.
    Dummyxl likes this.
  11. willverduzco
    Cupcake Nov 3, 2018
    Unclescrooge - Odd it's not working for me. I normally do not use OP launcher, but just now I switched to it, force closed it, cleared cache (for app not in recovery, as Android pie removed the cache partition that used to be cleared through recovery), and cleared app data... Still no go for me. Strangely I don't even have the close all button anymore! (screenshot)
    Thanks once again for all your help even if my device is missing the one feature I really wanted from this update.
    I wonder if it's a region locked feature right now since I have a North American unit (A6003).
  12. Lakshya Modi
    Eclair Nov 3, 2018
    Lakshya Modi , Nov 3, 2018 :
    No I am also feeling the same
  13. Siva_Prasad_022
    Cupcake Nov 3, 2018
  14. Lakshya Modi
    Eclair Nov 3, 2018
    When will it be available in India
  15. Siva_Prasad_022
    Cupcake Nov 3, 2018
    Siva_Prasad_022 , Nov 3, 2018 :
    Am also frm India still I didn't recieve
  16. G_Varun_Sathyanarayan_JI
    Cupcake Nov 3, 2018
  17. Unclescrooge
    Froyo Nov 3, 2018
    Well that is not the case i guess. A6003 Model of Oneplus 6 is for North American and European countries. The only difference between A6000 and A6003 is of Some LTE bands. And most people from those continents have already reported here that Gestures are working fine in them.
  18. W1536531382920
    Donut Nov 3, 2018
  19. willverduzco
    Cupcake Nov 3, 2018
    Hmm, odd. Are we sure users with the A6003 have had working new style gestures? I searched using the cumbersome search system in the mobile app and couldn't find anyone else with a 6003 device mention anything about gestures... In any case, I'll try a full wipe which clears the data partition (including per app caches) and report back in case anyone else has issues.
  20. pandispd6
    Eclair Nov 3, 2018
