685
OxygenOS 9.0.2 OTA for OnePlus 6
  1. Unclescrooge
    Froyo Nov 4, 2018
    Unclescrooge , Nov 4, 2018 :
    That rom file will take you back to stable version of Oreo(don't know which version). No one knows when the newer update will arrive. Although you can try a factory reset. See if that helps.
  2. edy90s
    Honeycomb Nov 4, 2018
    edy90s , Nov 4, 2018 :
    you cannot revert back with an official update , you need a roll back file.
  3. Unclescrooge
    Froyo Nov 4, 2018
    I was talking about that 'roll back' rom only.
    edy90s likes this.
  4. V1529921476159
    Cupcake Nov 4, 2018
    V1529921476159 , Nov 4, 2018 :
    please, you can change the multitasking screen with gestures, they are very uncomfortable.
    before they were much faster and did not give any problems
  5. Kumeresh
    Froyo Nov 4, 2018
    Kumeresh , Nov 4, 2018 :
    don't worry you will get soon. I could see there was a focus given for new devices. now with all rollout completed backlogs will be started to clear. some more time!!!!
  6. Deactivated User
    Nov 4, 2018
    Frezo likes this.
  7. Tumio
    Gingerbread Nov 4, 2018
    Frezo likes this.
  8. sergiolamarck
    Cupcake Nov 4, 2018
  9. nabbed
    nabbed , Nov 4, 2018 :
    See, you could have just said "Bettery!" :)
  10. alexferdean
    Ice Cream Sandwich Nov 4, 2018
    alexferdean , Nov 4, 2018 :
    It's not the same. With OnePlus launcher it works perfectly. With other launchers it's a bit slower and sometimes it takes you to an older app instead of the last used one.
  11. Deactivated User
    Nov 4, 2018
  12. Will93
    Eclair Nov 4, 2018
    Will93 , Nov 4, 2018 :
    how can I switch to OTA from beta, without that downgrade message.
  13. Deactivated User
    Nov 4, 2018
  14. MrStabsv1
    Froyo Nov 4, 2018
    MrStabsv1 , Nov 4, 2018 :
    8 hours 31 minutes screen on time with 11 percent left, very happy with the battery life.
    Frezo and anupambharti like this.
  15. Mat.PL
  16. Himcor
    Froyo Nov 4, 2018
    Himcor , Nov 4, 2018 :
    16h on battery, 4h sot. 15% battery left. Good job with the update!
    anupambharti likes this.
  17. Deactivated User
    Nov 4, 2018
    Mat.PL likes this.
  18. BalwinderSingh60
    Eclair Nov 4, 2018
  19. _dp_
    Donut Nov 4, 2018
    _dp_ , Nov 4, 2018 :
    It worked.. I updated it to 9.0 from Oreo after installing above file. Thanks.
  20. bharadwaj9r
    Cupcake Nov 4, 2018
