685
OxygenOS 9.0.2 OTA for OnePlus 6
  1. kristof.fleury
    Cupcake Nov 1, 2018
    Vladut123 likes this.
  2. Maverick2.0
    KitKat Nov 1, 2018
    Maverick2.0 , Nov 1, 2018 :
    Can someone please confirm if this update brings parallel apps support for Uber and Ola?
  3. edy90s
    Honeycomb Nov 1, 2018
    edy90s , Nov 1, 2018 :
  4. V1538978814648
    Cupcake Nov 1, 2018
  5. gautamthapar
    gautamthapar , Nov 1, 2018 :
    Yep. lol
  6. bujjigadusureo
    Froyo Nov 1, 2018
  7. gautamthapar
    Uber it's available. Ola no.
    Maverick2.0 likes this.
  8. pa5t1s
    User of the Year 2014 Nov 1, 2018
    pa5t1s , Nov 1, 2018 :
    Cool @Manu J..
    Please don't make us, members in FR, wait too long this time ;)
  9. B1532620287225
    Cupcake Nov 1, 2018
  10. gautamthapar
    For Nightscape it's a new option but can't find studio lighting feature.
  11. J1539632555875
    Cupcake Nov 1, 2018
  12. utsav17
    utsav17 , Nov 1, 2018 :
    Please decrease power menu from 3s to 2s or atleast 2.5s
    Also the new application menu is more transparent ...i think people prefer the earlier opaque one or atleastmore translucency.
    Also, still no clue about very basic and very necessary feature of manual orientation lock in either potrait or landscape (android 9 feature)
  13. bhargavkukadiya
    bhargavkukadiya , Nov 1, 2018 :
    Thanks for the help, I found a zip file inside .ota foder and removed the same and rechecked for software update and guess what it showed me to download OxygenOS 9.0.1 and now I finally downloaded and installed the same. After installing it, I rechecked for software update and there is no OxygenOS 9.0.2 available for me now. May be in India, it has not yet been came.
  14. bassopt
    bassopt , Nov 1, 2018 :
    This is how it works. You have re-apply root after every update
  15. Pt25
    Eclair Nov 1, 2018
  16. edy90s
    bhargavkukadiya
    Thanks for the help, I found a zip file inside .ota foder and removed the same and rechecked for software update and guess what it showed me to download OxygenOS 9.0.1 and now I finally downloaded and installed the same. After installing it, I rechecked for software update and there is no OxygenOS 9.0.2 available for me now. May be in India, it has not yet been came.​
    check with turbo vpn on Germany channel or Canada. Connect first to the Germany or Canada with turbo vpn , delete that file from .ota and then check for updates. after start download disconnect from vpn to have full speed from your wifi
  17. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Nov 1, 2018
    KeepTransisting , Nov 1, 2018 :
    Turn off the "Quick activate the assistant app" option and the power button only takes one second.
  18. bhargavkukadiya
    Okay just I want to know why VPN? Why every user is not getting at a time? or they are distributing in slots to check everything works fine?
  19. calculator120d
    Froyo Nov 1, 2018
    calculator120d , Nov 1, 2018 :
    Dude, didn't you read the OP??
    It is a staged roll out. You might get the update the very next moment or you might get it tomorrow or maybe day after tomorrow.
    Just be patient. Patience is the key!
  20. Harsh_Swmai
    Froyo Nov 1, 2018
