685
OxygenOS 9.0.2 OTA for OnePlus 6
  1. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Nov 12, 2018
    KeepTransisting , Nov 12, 2018 :
    1) Do the backup through OnePlus Switch
    2) Go to Settings > System > Reset options > Erase all data (factory reset)
    3) Make sure Erase internal storage is UNCHECKED and hit Reset Phone
    4) Once reset is complete, restore the backup using OnePlus Switch
    Flamingskull9 likes this.
  2. math3
    Cupcake Nov 12, 2018
    math3 , Nov 12, 2018 :
    4 hours sot..2 days (49 hours) from the last charge. I be done NO reset or anything else. Just upgrade to 9.0.2. OnePlus is the best.-
  3. R32W4N
    R32W4N , Nov 12, 2018 :
    Yes and after updates, not everyone gets the bugs. I've had this on previous phones where my friend has done the same update with the same phone and doesn't experience the bug.
  4. Karan vijaykumar
    Karan vijaykumar , Nov 12, 2018 :
    Hi,
    after updating to OS 9.0.2 am facing problem with speaker. Other person on call can't hear my voice. Any solution
  5. Charan Sai
    Eclair Nov 12, 2018
    R32W4N and Dashmeet Singh like this.
  6. Ashishkumar02
    Eclair Nov 12, 2018
    Ashishkumar02 , Nov 12, 2018 :
    anybody feel that pubg not running smoothly after this update in hdr mode it is lagging ...
    plz I am very trouble about the update
    it is cause draining of my battery faster
    iam not feeling the that speed which run on pie...
    R32W4N likes this.
  7. souravka6
    Gingerbread Nov 12, 2018
  8. vaibhavd129
    Donut Nov 12, 2018
    vaibhavd129 , Nov 12, 2018 :
    I'm not able to scroll the Google calender app in shelf.
    I don't frequently use the shelf till now so im not sure if I'm doing anything wrong or if it's an issue.
    I've kept the height of the app to be such that I can see 4-5 dates having some kind of event scheduled on them but when i scroll on the widget the whole shelf scrolls
  9. Reetej Kumar khadka
  10. bassopt
    Honeycomb Nov 12, 2018
    bassopt , Nov 12, 2018 :
    Hahahah typicaL oneplus screwing up battery after the launch of a new device. Must sell sell sell.
    Hahahahaha this is why I stoped buying one plus stufff. It happens all the time!!!!
  11. hjano
    hjano , Nov 12, 2018 :
    yes.. reboot to service mode (power + volume down), english, wipe cache ... and will be fine.. For me helped that
  12. hjano
    wipe the cache
  13. hjano
    wipe the cache...
  14. Einzele
    Einzele , Nov 12, 2018 :
    Since 9.0.2 I have ram issue with my phone. Then I check my ram usage under developer settings and found this. 1.6gb usage on oneplus launcher, and i dont event use it, I'm using nova launcher. Is this normal? Is oneplus always there even tho you don't use it?
  15. Shanmu1212
    Shanmu1212 , Nov 12, 2018 :
    my phone getting more heat while playing games (Pubg)...! please kindly resolve it...!
    Ge93 likes this.
  16. Shanmu1212
  17. KeepTransisting
    The OnePlus launcher does more than just a launcher. it actually handles some system stuff (for example, the new recents menu is part of the OnePlus launcher)
    Kytharsis likes this.
  18. SurenBejoy
    SurenBejoy , Nov 12, 2018 :
    Vibrate when answering functionality is not working after Oxygen 9.0.2 update. Pls suggest some solution.
  19. Deactivated User
    Nov 12, 2018
  20. G_F._Anton_KFBw
    Eclair Nov 12, 2018
    G_F._Anton_KFBw , Nov 12, 2018 :
    apps are closing in the Background quite often, seems like a memory problem to me, i mean we are talking about 6gb of ram.
