685
OxygenOS 9.0.2 OTA for OnePlus 6
  1. G_Amit_Parihar_cqvF
    Cupcake Nov 15, 2018
  2. Deactivated User
    Nov 15, 2018
  3. Dmitriy_Kirillov
    Eclair Nov 15, 2018
    Dmitriy_Kirillov , Nov 15, 2018 :
    Found a firmware bug. Avatar in the blind notice is dark. When you select some items, the pop-up menu is not displayed completely, text is not visible. The clipboard does not work correctly, in some places it does not work at all, I can not bring up the menu (copy, paste and others)
  4. makavellu
    Donut Nov 15, 2018
    makavellu , Nov 15, 2018 :
    @sollar eclipse or how the hell is your name
    It's obvious that you cannot understand simple logic
    Sorry for you .
  5. W1537209647933
    W1537209647933 , Nov 15, 2018 :
    hello, I have a problem with oneplus6 namely, I noticed that the vibration does not work only when starting the phone .. what could be a problem?
  6. edy90s
    Honeycomb Nov 15, 2018
  7. Tclarke-94
    Gingerbread Nov 15, 2018
    Tclarke-94 , Nov 15, 2018 :
    never experienced anything like this before 9.02
  8. berkayyildiz93
    Donut Nov 15, 2018
  9. Deactivated User
    Nov 15, 2018
    Artemus. likes this.
  10. J1529218718170
    Eclair Nov 15, 2018
  11. Deactivated User
    Nov 15, 2018
  12. kaihp
    Jelly Bean Nov 15, 2018
    kaihp , Nov 15, 2018 :
    It would a good starting point not to call other users for "idiots" and at the same time call for "respect and decency".
  13. dany973
    Eclair Nov 15, 2018
    dany973 , Nov 15, 2018 :
    Good Job for the update.
    The camera need a quality improvement and the sound (speaker) need a equalizer and it will be perfect.
    Thanks you. [e]1f601[/e][e]1f601[/e][e]1f601[/e][e]1f601[/e][e]1f601[/e]
  14. edy90s
    edy90s , Nov 15, 2018 :
    After an major update (Android version changed) it's recommend an factory reset :)
  15. sblantipodi
    sblantipodi , Nov 15, 2018 :
    night mode is a marketing gimmick. it's completely unuseful, images are blurried with pretty no stabilization
  16. Artemus.
    Nougat Nov 15, 2018
    Artemus. , Nov 15, 2018 :
    That's because you're supposed to be the stabilizer.
    LGoldson likes this.
  17. Deactivated User
    Nov 15, 2018
  18. Tclarke-94
    explain this then because with the same apps and usage I used to get double the screen on I am currently getting right now. and I have been using android since 1.6 donut so I know how troubleshoot android issues especially with battery. the update 100% had a negative effect on my battery I. have had the phone for 3 months and haven't complained about battery once until 9.0.2 I had better battery on beta 6 then I thought I might as well move to stable for I don't know what reason but I did and 8 have suffered for it.
    sanjai10 likes this.
  19. Deactivated User
    Nov 15, 2018
  20. Tclarke-94
    updates effects different devices different just because one person faces a bug doesn't mean everyone should, I feel like you are missing the fact that on everyone every update I keep the same apps I don't add or change anything I have the same set up for years literally I was getting 7 hours sot before moving to 9.02 and i am now getting 3 hours with the same set up so it's not my usage if my habits have not changed at all. you keep missing the important things of what I am saying. I am 100% more familiar with android than you I am 100% certain like I said I have been using android since the first version. I know all the tips and tricks etc.
    JAcunio likes this.
