684
OxygenOS 9.0.2 OTA for OnePlus 6
  1. Lupastro82 Froyo Dec 3, 2018
    Lupastro82, Dec 3, 2018 :
    No more update for OP6? Maybe is best to go in beta channel? If yes, do this cause hard reset or I can switch from 9.0.2 to beta 8 without problems and without reset?
    Thanks.
  2. KeepTransisting The Lab - OnePlus 7 Pro Reviewer Dec 3, 2018
    KeepTransisting, Dec 3, 2018 :
    You can flash the beta without any problems and without a reset. However, you will need to reset if you decide to go back to stable.
    Lupastro82 likes this.
  3. Lupastro82 Froyo Dec 3, 2018
  4. B1540323196290 Cupcake Dec 3, 2018
  5. prfraczek Honeycomb Dec 3, 2018
  6. Kytharsis Lollipop Dec 3, 2018
    Kytharsis, Dec 3, 2018 :
    Yes. But if you have to ask, you're better off staying away from beta.
  7. prfraczek Honeycomb Dec 3, 2018
    prfraczek, Dec 3, 2018 :
    why?
  8. Kytharsis Lollipop Dec 3, 2018
    For one, you'll have to deal with bugs that might occur. And for two, the process of returning to stable in case you don't like beta requires wiping your phone.
  9. S1543872690312 Cupcake Dec 3, 2018
    S1543872690312, Dec 3, 2018 :
    I'm a great fan of OnePlus phone. I used the oneplus3T and it was smooth and never disappointed me. now I'm using the oneplus6 and sometimes it just hang automatically, after two or three minutes the light come back and demand for password. I'm very disappointed
  10. Deactivated User Dec 3, 2018
  11. L1535879402668 Gingerbread Dec 3, 2018
    L1535879402668, Dec 3, 2018 :
    what's the battery like after the 9.0.2. I've deliberately held off to see what ppl are saying. anyone having battery issues.
  12. rohitsharma_j22 Froyo Dec 4, 2018
    rohitsharma_j22, Dec 4, 2018 :
    I am facing a weird issue. If I have locked any recent app, then on clearing recent apps, sometime locked app also getting clear, probability is like 1 out of 10 times. Faced many times. Anybody else face this issue??
  13. S1543872690312 Cupcake Dec 4, 2018
    S1543872690312, Dec 4, 2018 :
    I've done nothing with my phone. I'm using this one just like i used the oneplus3T and the apps also.
  14. S1543872690312 Cupcake Dec 4, 2018
    L1535879402668
    what's the battery like after the 9.0.2. I've deliberately held off to see what ppl are saying. anyone having battery issues.​
    Battery life is as expected, awesome.
    andythw and L1535879402668 like this.
  15. S1543872690312 Cupcake Dec 4, 2018
    Well i saw in internet that do not ever close the recent app because there is a option like the phone automatically close the recent app after every 3 hours that's how the RAM run smoothly because after closing a recent app it takes 2 or 3 sec to reopen the app. and I've never face the app locking problem.
  16. Luis171 Donut Dec 4, 2018
    Luis171, Dec 4, 2018 :
    Don't update to 9.0.2 it destroys battery life and here are tonne of bugs. Feels like a bad beta release.
    L1535879402668 likes this.
  17. landov Froyo Dec 4, 2018
    jasonanouk and L1535879402668 like this.
  18. rohitsharma_j22 Froyo Dec 4, 2018
    But if some apps which are not of any use for me, Why i waste my ram to let them remain in memory. Its better to spend 2-3 secs in reopening them whenever they needed.
  19. peaky blinders Jelly Bean Dec 4, 2018
    peaky blinders, Dec 4, 2018 :
    The option to choose the apps would not be there if it wasn't ok to do so. It won't do anything to the RAM apart from help it
  20. K1543922584518 Cupcake Dec 4, 2018
    K1543922584518, Dec 4, 2018 :
    this update sucks so bad.
    please do not upgrade your device guys.
    mobile and wifi network is unstable after this update,
    battery drain is also a problem.
    i downgraded to oreo, a much more stable update.
    experiencing 0 problems in oreo oxygen 5.1.11
