684
OxygenOS 9.0.2 OTA for OnePlus 6
  1. manasarora98 Honeycomb Dec 5, 2018
    manasarora98, Dec 5, 2018 :
    Amazing....can you tell me if it was clean wipe or normal system update you performed?
    and How do you get an LTE connectivity (enhanced 4G), I am stuck on 4G on both sims. Which country are you in?
  2. Kytharsis Lollipop Dec 5, 2018
    Kytharsis, Dec 5, 2018 :
    Normal system update, AT&T towers have good signal apparently, US.
  3. manasarora98 Honeycomb Dec 5, 2018
  4. UnicornKaz Ice Cream Sandwich Dec 5, 2018
    UnicornKaz, Dec 5, 2018 :
    Yup...I concur ! :D .... here's mine as it is used up...etc.
    E1540491015149 likes this.
  5. G_sai_goutham_HMNR Froyo Dec 5, 2018
    G_sai_goutham_HMNR, Dec 5, 2018 :
    it's already been more than a month that this update has released. any idea on the new update.. when it gonna release as there are issues with the current.
  6. V1529405682255 Cupcake Dec 5, 2018
    V1529405682255, Dec 5, 2018 :
    facing very bad issue with heating while using camera.
    from last 4 months.
    temperature rise up to 41°c
    such a chucked up guys.
    very bad experience with one plus 6
  7. Lewana83 Cupcake Dec 5, 2018
    Lewana83, Dec 5, 2018 :
    Hello guys
    After last to updates on my OnePlus 6 software I start have some problems
    1) I send text but get info it is not send, even if recipient get the txt
    2) the weather, mail and news apps don't refresh automatically I need to do manually
    3) after some apps update they don't install as long I don't restart phone
    4) I can't open any attachments from email
    That is my current OS version in UK. Any help or advice ⁉️
  8. Q1526111421452 Donut Dec 5, 2018
    Q1526111421452, Dec 5, 2018 :
    I think we may have a security issue or I can't find the setting options...
    Problem: when Status bar is dragged down, many options like network and GPS can be disabled without unlocking my phone.
    If my phone got lost, it is necessary that network and GPS must be enabled to track my phone down using Google find my device or third party software
    OR..is there any other option to disable some of the options in drag screen when unlocked but it is visible when it is unlocked..
    OR some other precautionary actions to be taken
    Thanks in advance..
    JAGADISH BHATTA likes this.
  9. Cervantes Lollipop Moderator Dec 5, 2018
    Cervantes, Dec 5, 2018 :
    The thread of the update is a thread of questions
    You can clean the temporary memory: wipe cache
    Please, use the topic search instead of opening a new thread
    Thread merged
  10. Parthkansara Eclair Dec 5, 2018
    Parthkansara, Dec 5, 2018 :
    poco f1 ne apne beta version me 960fps slo mo de diya hai... or ham abhi bhi jerky 480 fps me atke hue hai... agar poco f1 960 fps slo mo de sakta hai to oneplus bhi 6 or 6t me 960 fps de hi sakta hai... kyuki oneplus 6/t ka camera better hai poco f1 se... so plz add 960fps video recording feature. it is now math.
  11. UnicornKaz Ice Cream Sandwich Dec 5, 2018
    My network can be access...my location cannot be access without providing the lock pattern. ( my case)
    There's something foul at your end.
  12. K1531564768947 Donut Dec 5, 2018
  13. Kytharsis Lollipop Dec 5, 2018
    This has been standard for Android for a long time.
    UnicornKaz likes this.
  14. vamshai Cupcake Dec 5, 2018
    vamshai, Dec 5, 2018 :
    is your battery problem solved after factory reset
  15. damarse2 Cupcake Dec 5, 2018
    damarse2, Dec 5, 2018 :
    there's a bug on clash Royale. On this beta you cannot open this app on full screen mode, and therefore, there are some black bars on the top a the bottom.
  16. shijopj2014 Honeycomb Dec 5, 2018
    shijopj2014, Dec 5, 2018 :
    Yes almost...now I am getting an average of 7 to 8 hrs of SOT. But still it seems to be lesser than Oreo.
    thanks
    vamshai likes this.
  17. Parthkansara Eclair Dec 5, 2018
    can u upload screenshot of your battery usage? nd which app u use?
  18. Kytharsis Lollipop Dec 5, 2018
    Not a bug. It's not optimized for 19:9 screens.
  19. shijopj2014 Honeycomb Dec 5, 2018
    Parthkansara likes this.
  20. Deactivated User Dec 5, 2018
