685
OxygenOS 9.0.2 OTA for OnePlus 6
  1. Cervantes
    Moderator Moderator Dec 5, 2018
    Cervantes , Dec 5, 2018 :
    The thread of the update is a thread of questions
    Please, read the first post
    use the topic search instead of opening a new thread
    Thread merged
  2. A1541676391873
    Cupcake Dec 5, 2018
  3. Deactivated User
    Dec 5, 2018
    andythw likes this.
  4. ade0410
    Ice Cream Sandwich Dec 5, 2018
    ade0410 , Dec 5, 2018 :
    no it's not.
    you're just ugly.
    can't polish a turd.
  5. sriramsss87
    Donut Dec 6, 2018
    sriramsss87 , Dec 6, 2018 :
    waiting for the same, battery drain 2×before update
    has anyone found a solution
  6. Deactivated User
    Dec 6, 2018
    sriramsss87 likes this.
  7. sriramsss87
    Donut Dec 6, 2018
    thanks
    pls don't mistake me,
    I had the same apps before the update 9.0.2
    after the update now I have to blame the apps for draining my battery
    there should be some other problem?!
    L1535879402668 likes this.
  8. Deactivated User
    Dec 6, 2018
    Artemus. likes this.
  9. Harsh_Swmai
    Froyo Dec 6, 2018
    Harsh_Swmai , Dec 6, 2018 :
    what's wrong going on @Manu J.
    the system u.i stopped working .
    the screen is paused to any window then it turns black and sometime device automatically gets restarted
    what's the problem ?
  10. Artemus.
    Community Hero 2020 Dec 6, 2018
    Harsh_Swmai likes this.
  11. Harsh_Swmai
    Froyo Dec 6, 2018
    brother these are the magical words that all the device manufacturer says all the time
  12. Artemus.
    Artemus. , Dec 6, 2018 :
    I'm not your brother, cousin!
  13. Harsh_Swmai
    Froyo Dec 6, 2018
  14. peaky blinders
    Jelly Bean Dec 6, 2018
    peaky blinders , Dec 6, 2018 :
    Always battery drain when there isn't. limit apps from running in the background. Install Greenify from Google Play store. Battery drain is down to the apps installed ie Facebook, Snapchat etc, etc will kill your battery. If you have lots of notifications this kill your battery.
    I'd say 99.9% of people moaning about battery drain is down to the user not the device
    Deactivated User and UnicornKaz like this.
  15. UnicornKaz
    Ice Cream Sandwich Dec 6, 2018
    UnicornKaz , Dec 6, 2018 :
    ...Same cycle (see time stamp)...still going...and going.., :sleepy: got a couple of active alarms snoozed going on at that time. :p
    FYI...Not all apps usage will show up in the page...I've used others in this cycle but they are not listed.:confused:
    I don't know for what rhyme or reason .. Google designed PIE that way I supposed. :cool:
  16. UnicornKaz
    Yeah...And it existed in custom roms even earlier....Google just adapt/evolve (github) ...Linux is open source ...etc. ;)
  17. UnicornKaz
    Can I add some tips to that ? :D
    Keyboard !! SOUND & VIBRATIONS...
    It's a personal choice...But realize that it also will drain rapidly if you enabled ! :cool:
    peaky blinders likes this.
  18. Sarang Mohan
    Donut Dec 6, 2018
    Sagar905 likes this.
  19. 11harsh22
    Cupcake Dec 6, 2018
    11harsh22 , Dec 6, 2018 :
    battery draining problem is still there...did wipe cache, wipe data both..but still no help
    only 3 hrs screen usage time when battery 33,%left.
  20. jasonanouk
    Eclair Dec 6, 2018
    jasonanouk , Dec 6, 2018 :
    same here no issues at all. no lag, it just wirks
    andythw and Sagar905 like this.
