685
OxygenOS 9.0.2 OTA for OnePlus 6
  1. LegolasX
    Jelly Bean Dec 6, 2018
    LegolasX , Dec 6, 2018 :
    1. why don't you search and read the solution which has been posted 1000 times already?
    2. its how it should be working and set as default.
    3.no such issues, clear app data or cache
    4.no such issue, works as it is supposed to.
    5. its excellent, it lasts more than 4 days on standby for me.
    tldr find out apps or any other reason why its working for you.
    robin143 likes this.
  2. UnicornKaz
    Ice Cream Sandwich Dec 6, 2018
    UnicornKaz , Dec 6, 2018 :
    You need to hold your touch a bit longer on the screen...and DRAG down a bit longer as a gesture....DON'T FLICK !
    ^^*...user error...o_O
    Sarang Mohan likes this.
  3. UnicornKaz
    You shouldn't be holding your breath when you have Oxygen.
    OXYMORON ! :p
    ...Not you... :D
  4. Filipe_C_E
    Gingerbread Dec 6, 2018
    sriramsss87 likes this.
  5. neel9i11
    Donut Dec 6, 2018
    neel9i11 , Dec 6, 2018 :
    2. no, its not how it should be working. there is no separate setting for in-out going calls.
    3. it's not limited to one app that i can clean cache or update it. it happens in everyapp when typing. (yes keyboard itself , gboard, is up to date.
    4. not displaying last content in last used app in recent app tab is not something I've seen before. it is an error for sure.
    5 I'm glad it's working for you but battery drain in this update is not something I'm only one complaining. I've got 3 op6 in my family.
    tRouBLE_mE likes this.
  6. guolei329
    Cupcake Dec 6, 2018
  7. Deactivated User
    Dec 6, 2018
  8. Deactivated User
    Dec 6, 2018
  9. LegolasX
    2. as i said its by default and there are no separate settings for that.
    3.its obviously the apps that have issues, since a lot of them are yet to get Pie compatibility.
    4.i have no such issues and i think many other users too don't have this issue, so it makes clear the issue is not due to update.
    clear launcher data to check.
    5. battery life is different on each and every phone. no matter how many phones you own non of them will have exact same usage nor same battery life.
    and it's a good move to factory reset the devices if you face too much issues and check.
  10. Filipe_C_E
    Filipe_C_E , Dec 6, 2018 :
    No,really...
  11. Deactivated User
    Dec 6, 2018
  12. Luis171
    Donut Dec 6, 2018
    Luis171 , Dec 6, 2018 :
    People still saying there are no issues with this update? 350 pages on this thread and people still putting head head in the sand.
  13. Deactivated User
    Dec 6, 2018
    Deactivated User likes this.
  14. Luis171
    Donut Dec 6, 2018
    How do you explain that people such as myself that updated to 9.0.2 and kept the same apps and exactly the same usage pattern and are getting 30-50% less battery time? It has nothing to do with the update? How delusional do you have to be to believe that?
  15. Deactivated User
    Dec 6, 2018
    oscarbianca0607 likes this.
  16. tRouBLE_mE
    Froyo Dec 6, 2018
  17. tRouBLE_mE
    Froyo Dec 6, 2018
    tRouBLE_mE , Dec 6, 2018 :
    Even I am facing the battery drain and it's intense. The apps are same as before and the usage is also the same as before the update. Even tried formatting it numerous times. Also checked the battery stats for apps but they are useless.
    Sudhanshu Joshi SDD likes this.
  18. Luis171
    Donut Dec 6, 2018
    The apps didn't change. They were working properly with the previous update. Stable releases should to just that, stable. It's ridiculous to ask users to clear caches or do a full reset just to keep their phone working properly, that's what betas are for.
    You are getting good battery life, good for you, a lot of people aren't, so there's clearly an issue and blaming it on users isn't helping Onepluse's cause.
  19. tRouBLE_mE
    Froyo Dec 6, 2018
    I have also done a complete data wipe as well. But it was useless.
  20. Luis171
    Donut Dec 6, 2018
    Read exactly the same thing which is why I didn't bother, and we shouldn't have to. It just encourages companies to pull shitty updates like this in the future.
    L1535879402668 likes this.
