684
OxygenOS 9.0.2 OTA for OnePlus 6
  1. Sarang Mohan Cupcake Dec 6, 2018
    Sarang Mohan, Dec 6, 2018 :
    Thanxx buddy
  2. Deactivated User Dec 6, 2018
  3. tRouBLE_mE Froyo Dec 6, 2018
    tRouBLE_mE, Dec 6, 2018 :
    I just let the update to install automatically including the apps. Also all of the apps are updated to the latest version and as I mentioned before, I use the same apps as before the update.
  4. Trevor.Hawkes Ice Cream Sandwich Dec 6, 2018
    Trevor.Hawkes, Dec 6, 2018 :
    While I don't believe in the " I've got the same update as you and don't have the problem so it's your fault" stance I do see why so many people say it's not the update itself.
    I know that the bad battery after updating isn't only a complaint on OnePlus phones.
    Most Android phones suffer from it.
    The problem has to be related to settings or apps, or a combination of both, on the phones. I have 9.0.2 and definitely do not have a battery problem. You definitely do have it.
    The difference between our phones is usage, settings and apps.
    Your usage hasn't changed so there's not much left.
    No one, to my knowledge has an answer to this.
    My only other input is that on my 3 I had the problem and I did the usual things without curing it. However, after around a week or two I realized my battery was getting back to normal. I hope this happens for you.
    tRouBLE_mE likes this.
  5. Deactivated User Dec 6, 2018
  6. tRouBLE_mE Froyo Dec 6, 2018
    I don't follow o_O
  7. L1535879402668 Gingerbread Dec 6, 2018
    L1535879402668, Dec 6, 2018 :
    While 9.0.3 needs to happen, I'd rather they took a month or two and got it completely right. I don't need monthly updates. Annual updates are fine. Just give me one good solid update where the battery is fantastic and everything else works fine- just like the days before pie.
    Battery matters to people- it's worth making this an absolute priority. All the chat about apps not being ready for pie bores me. If the apps aren't ready then pie is ineffective because it's too advanced for the apps ppl use. If thats the case then revert to the old system and wait til the apps are ready. Not that I believe that's really the issue at all here. I think the developers just wanted to make a blisteringly fast and impressive device and they did that at the expense of the battery life.
    YellowClaw, tRouBLE_mE and Ricanstyle like this.
  8. Ricanstyle Froyo Dec 7, 2018
    Ricanstyle, Dec 7, 2018 :
    Battery matters to people- it's worth making this an absolute priority. All the chat about apps not being ready for pie bores me. If the apps aren't ready then pie is ineffective because it's too advanced for the apps ppl use. If thats the case then revert to the old system and wait til the apps are ready. Not that I believe that's really the issue at all here. I think the developers just wanted to make a blisteringly fast and impressive device and they did that at the expense of the battery life.[/QUOTE]
    Give this man an award, I couldn't have said it better myself. We will NEVER SETTLE for this!
    L1535879402668 likes this.
  9. Iloyola Cupcake Dec 7, 2018
    Iloyola, Dec 7, 2018 :
    I would like to update my android... but size is approximately 1.5 Gb, is that OK?... and if I update, will I lose my information?
  10. Msv_Vamsi Gingerbread Dec 7, 2018
  11. YellowClaw Honeycomb Dec 7, 2018
    YellowClaw, Dec 7, 2018 :
    No you won't loose any info.
  12. FaleshC KitKat Dec 7, 2018
    FaleshC, Dec 7, 2018 :
    boot loader unlocked?
  13. Iloyola Cupcake Dec 7, 2018
    No, my bootloader is locked.
  14. FaleshC KitKat Dec 7, 2018
    ah, okay.
    what version were you before 9.0.2?
    and to your answer, no it won't wipe anything during update.
  15. Iloyola Cupcake Dec 7, 2018
    Now, I have 5.1.11 Oxygenos.
  16. FaleshC KitKat Dec 7, 2018
    okay, that explains the huge size.
    perfectly fine to update if you wish to.
  17. laikexpert Eclair Dec 7, 2018
    Msv_Vamsi likes this.
  18. Msv_Vamsi Gingerbread Dec 7, 2018
    Msv_Vamsi, Dec 7, 2018 :
    hmm... can't post this bug in feedback ...some login issue
  19. X1531817552743 Cupcake Dec 7, 2018
    X1531817552743, Dec 7, 2018 :
    phone get automatically disconnects and unable to search contact through search option in contacts happens many time I need to close and open again or restart the phone sometimes
  20. X1531817552743 Cupcake Dec 7, 2018
    whenever I make a call it gets disconnected automatically unable to make the calls to anyone and even when I search for. contacts im unable to search it shows that no contacts
