685
OxygenOS 9.0.2 OTA for OnePlus 6
  1. sahirhussain
    Honeycomb Dec 12, 2018
  2. J1529218718170
    Eclair Dec 12, 2018
    J1529218718170 , Dec 12, 2018 :
    please fix the battery issues draining so much faster as compared to previous OTA
    please please please
  3. H1535106412349
    Donut Dec 12, 2018
    H1535106412349 , Dec 12, 2018 :
    Im notice when we on Bluetooth something happened
    system UI not responding that happens same om Instagram and messenger app when open app not responding plz solve this
    Hari_play likes this.
  4. UnicornKaz
    Ice Cream Sandwich Dec 12, 2018
    UnicornKaz , Dec 12, 2018 :
    At the "battery optimization" screen...did you click on the 3 dots (upper right corner)...to check and see if BOTH options in the "advanced" menu are OFF ?
    I think you did but I'm not quite sure by reading your post.
  5. Arigali
    Donut Dec 12, 2018
    Arigali , Dec 12, 2018 :
    Yes, that is one is the things I do while setting the phone (I made numerous factory resets with different versions, Open betas, etc). Thank you for the suggestion
  6. RomeoD
    Gingerbread Dec 12, 2018
  7. bassopt
    bassopt , Dec 12, 2018 :
    I had diarrhea from prawn masala I ate at a curry house in Peckem! Either than that, no....
  8. O1529078668972
    Cupcake Dec 12, 2018
  9. ade0410
    ade0410 , Dec 12, 2018 :
    if you mean when you say "hey Google" then no it's not broken. mine works perfectly.
    maybe it's your voice?!
  10. O1529078668972
    O1529078668972 , Dec 12, 2018 :
    Yes, that's what I mean. And good to know yours is working fine but mine's not. I tried re-registering my voice, reboot the phone etc etc and it still doesn't recognise
  11. O1529078668972
    Also, when I try to retrain the voice model it's not accepting any input even though I keep saying 'ok Google' to retrain the model. And I don't think so there's any problem with the microphone input because calls are perfectly fine
  12. O1529078668972
    This problem doesn't seem to be isolated incident. A friend of mine has a 5T Star wars edition and even he is facing th exact same issue
  13. RomeoD
    RomeoD , Dec 12, 2018 :
    thank You! i was just wondering how are u today.
    any update for op6? because after 6t launch i see that op6 is history. it is just a simple question. no reason for You to answer like that.
    and take care with prawn masala in the future, ok?
    have a nice day!
  14. Deactivated User
    Dec 12, 2018
  15. J1529218718170
    Eclair Dec 12, 2018
    this is thing right ?
  16. J1529218718170
    Eclair Dec 12, 2018
  17. Y1542084516389
    Y1542084516389 , Dec 12, 2018 :
    There is an issue while waking up the device with double tap, it wont work some times on OnePlus 6
    Pls do something about it
  18. Sandipkadiya
  19. Deactivated User
    Dec 12, 2018
    5star02707 and Y1542084516389 like this.
  20. Divyanshu_Sankhwar
    Divyanshu_Sankhwar , Dec 12, 2018 :
    It doesn't work when you are in battery saving mode.
    Works fine otherwise
