685
OxygenOS 9.0.2 OTA for OnePlus 6
  1. LegolasX
    KitKat Dec 14, 2018
    LegolasX , Dec 14, 2018 :
    nobody is stopping you from downgrading. you need permission to downgrade?
    joetan900 likes this.
  2. joetan900
    Cupcake Dec 14, 2018
    joetan900 , Dec 14, 2018 :
    but downgrading will retain all apps data as per upgrading ?
  3. Artemus.
    Community Hero 2020 Dec 14, 2018
    Artemus. , Dec 14, 2018 :
    Nope. That's why you back up your stuff.
    UnicornKaz likes this.
  4. LegolasX
    KitKat Dec 14, 2018
    thats one disadvantage of downgrading, you lose stuff.
    thus backup is really important for the data.
    UnicornKaz and Artemus. like this.
  5. manasarora98
    Ice Cream Sandwich Dec 14, 2018
    manasarora98 , Dec 14, 2018 :
    Feedback to Devs:
    Damn, quite sometime handling the not so stable version 9.0.2, We need some features brought in Beta Releases, also fix the bugs asap. 9.0.3 Awaited.
  6. peaky blinders
    Jelly Bean Dec 14, 2018
    peaky blinders , Dec 14, 2018 :
    Looks like it could be a problem with the slider. I would take it to a service centre or contact OnePlus to fix this for you.
  7. rohitsharma_j22
    Gingerbread Dec 14, 2018
    rohitsharma_j22 , Dec 14, 2018 :
    Hi,
    I am facing issue with Google app's Live cricket score notification. It is not getting update automatically with time. Notification use to stuck at a score and then there is no auto updation. However it is working fine with Pixel phones, I have checked personally with my friend's phone. I have reported this issue to google too, but not sure wether this is an app side issue or OS related one.
  8. kaihp
    kaihp , Dec 14, 2018 :
    You should learn to read I guess.
    "every 2 months" = "bimonthly".
  9. Artemus.
    Correction: every two consecutive months. We'll get January's much like the last was September's.
  10. malay7904
  11. Ranjit_Singh_
    Eclair Dec 14, 2018
  12. UnicornKaz
    UnicornKaz , Dec 14, 2018 :
    It's the 1st screen you encountered when you 1st entered the BATTERY MENU...how did one ended up at the 2nd without seeing the 1st ? :confused:o_O
    ..."Who's on 1st...?" :D
    Artemus. likes this.
  13. Trevor.Hawkes
    Trevor.Hawkes , Dec 14, 2018 :
    The two months business kicks in during the third year. There is no frequency of release given for the first two years.
  14. francefries
    Eclair Dec 14, 2018
    francefries , Dec 14, 2018 :
    Yeah my bad...got it right... [e]1f44d[/e]
  15. UnicornKaz
    PHENOMENAL is my experienced...it just getting better & better with each cycle...etc.
    Noticed the "Google Play Services" high on the top of list ? ... well, click on it and the REAL info would surprise ya ! :cool: ... I guess I managed to "SHUT IT DOWN" :D ... helps to do it properly at the start of setup.
    https://forums.oneplus.com/threads/...ve-battery-life.837232/page-602#post-19579784
    If you click through your list...you'll find that the actual usage amount does NOT reflect the position on the list...basically...the lower items might have more usage time than the top listed item....etc....I just happened to shut down permissions through reading & researching.
    :p
    Google Play Service 2nd screen...
    :D
    Artemus. and Deactivated User like this.
  16. UnicornKaz
    LOL...Life lessons. :D
  17. zer0se7en
    zer0se7en , Dec 14, 2018 :
    You are asking for a fix from OnePlus when your problem is because of a third party app.
    Dude, contact the app developer of that certain app you're having problems with. He should be the one doing the fixing to make it completely compatible with OnePlus Oxygen OS devices.
  18. Tinkukumargupta
    Tinkukumargupta , Dec 14, 2018 :
    oxygen 9.0.2 Version is better but the remark is brightness was not good comparing to previous version and also need to change font styles
  19. ngydat
    Lollipop Dec 14, 2018
    ngydat , Dec 14, 2018 :
    That's because Google changed the algorithm for the screen brightness on Pie so you can't compare with what you had before.
  20. robin143
    Honeycomb Dec 14, 2018
    robin143 , Dec 14, 2018 :
    That doesn't means the everyone in the fourm is lieing.
    Otherthan battery drain and heating ,,Today I experienced one bug , the volume automatically reduced to low level. This is the third time in this month.
