685
OxygenOS 9.0.2 OTA for OnePlus 6
  1. ngydat
    Lollipop Dec 14, 2018
    ngydat , Dec 14, 2018 :
    With Bluetooth ? Did you enable "Absolute volume" in the sound settings (earphone mode) ?
    Artemus. likes this.
  2. Tinkukumargupta
    Cupcake Dec 14, 2018
    Tinkukumargupta , Dec 14, 2018 :
    and what about font styles
  3. UnicornKaz
    Ice Cream Sandwich Dec 14, 2018
    UnicornKaz , Dec 14, 2018 :
    What about it ? ... help me understand. o_O :confused:
    This falls under "personal taste/preference" ... -->> styles
    Don't like something ? what's stopping YOU from customizing it to your own ?
    Nice having choices, isn't it ? :cool:
  4. robin143
    Honeycomb Dec 14, 2018
    robin143 , Dec 14, 2018 :
    No bluetBlue and no.headset.. i only made my phone to vibrate mode , and when i change to ring .. the ring vol changed to low
  5. ngydat
    Why are you asking me as if I I was part of One Plus ?
  6. kaihp
    Jelly Bean Dec 14, 2018
    kaihp , Dec 14, 2018 :
    Maybe I'm reading it wrong, but I'm pretty sure that they meant every two months for the first two years, and then only security patches for the 3rd year:
    (graciously stolen from Post 1 of the OnePlus Software Maintenance Schedule thread)
    UnicornKaz likes this.
  7. Deactivated User
    Dec 14, 2018
  8. Deactivated User
    Dec 14, 2018
  9. kaihp
    So... you're saying every 2 months, and I'm saying every 2 months.
    What are we disagreeing about?
  10. 4sheesh
    4sheesh , Dec 14, 2018 :
    What is wrong with play services ???
    already downgraded two time and then Updated to pie bt this is making me sick every time
    cleared cache via recovery , Flashed fon via MSM downloader in Qualcomm mode !!!
    anyone have any solution plz tell me
  11. Trevor.Hawkes
    Trevor.Hawkes , Dec 14, 2018 :
    No, you're correct. On the the bar chart it say both the two years and the one year are bimonthly.
    However I was only reading the large text underneath which doesn't say bimonthly for the two years. Well spotted. Thank you.
    Thinking about it the two year updates should be more frequent sometimes but I suppose a fixed time is better than anytime they like.
    kaihp likes this.
  12. Deactivated User
    Dec 14, 2018
  13. 4sheesh
    thanks bro , bt these simple tricks doesn't work .....
  14. Deactivated User
    Dec 14, 2018
  15. kaihp
    Ah, now I understand you. So I'm saying updates every 2 months "from day one", whereas you say they only show up after 2 years.
    Now it wouldn't make sense for OnePlus to not provide updates the first two years and then suddenly during the third year, would it?
  16. ajjukhan312
  17. Artemus.
    Community Hero 2020 Dec 14, 2018
    Artemus. , Dec 14, 2018 :
    There's a setting to disable automatic WiFi switching. Though, even with this off, certain apps (like Maps) will enable it for better accuracy.
  18. Deactivated User
    Dec 14, 2018
  19. Z1543174283089
    Z1543174283089 , Dec 14, 2018 :
    i just got my op 6 6g ram. As i notice the ram i use is always above 60% and reaches easily 78% with one or two apps. Is this normal? Do i make something wrong? Can i fix it somehow?
  20. Artemus.
    The more RAM used, the better.
