685
OxygenOS 9.0.2 OTA for OnePlus 6
  1. AcmE85
    Ice Cream Sandwich Dec 17, 2018
    AcmE85 , Dec 17, 2018 :
    If you and your friend forgot the PIN/Password/Pattern and even the fingerprint does not work for your friend ;) ;) ;),
    there is NO WAY to get access to the system again without doing a factory reset from recovery (including data loss).
    Including security functions would be pointless if there was a workaround for them.
    Imagine someone finds your phone and is able to access your data...
    Kytharsis likes this.
  2. Inwithsj
    Froyo Dec 17, 2018
    sagarkr8shna likes this.
  3. D1545000383503
    Cupcake Dec 17, 2018
    D1545000383503 , Dec 17, 2018 :
    My camera is experiencing a shutter lag of atleast half a second or more after the 9.0.2 update. Is a solution being worked on?
  4. caruni
    Donut Dec 17, 2018
    robin143 likes this.
  5. ngydat
    KitKat Dec 17, 2018
    ngydat , Dec 17, 2018 :
    Your post serves no purpose at all.
  6. caruni
    Donut Dec 17, 2018
    caruni , Dec 17, 2018 :
    With oxygen 9 about 1.5 days with "many standby".
    And I also have tried betas, last one was 7. Same problem.
    With oxygen 5.1.11, see here:
    That says all. Maybe for "one of the reasons" with oxygen 9 is the wifi is always enabled and no possibility to change it.
    Fact is, with 5.1.11 the battery life is amazing, so it is not the device the problem, but the firmware.
    With 5.1.11 just having the problem, that after about 3 days the system asks me again for my password and the all the apps where I login with fingerprint don't accept more the fingerprint (about 6 banking apps). So every 3 days register again fingerprint...
    At the moment I am really not happy with the device...
  7. Deactivated User
    Dec 17, 2018
  8. Deactivated User
    Dec 17, 2018
  9. Deactivated User
    Dec 17, 2018
  10. a.audiovisuales
    a.audiovisuales , Dec 17, 2018 :
    Incoming call. Not black screen.
  11. ngydat
    KitKat Dec 17, 2018
    When I ask you a question with an "OR" in it, please answer correctly : if I ask A or B ? there are 4 possibilities :
    - only A
    - only B
    - A AND B
    - neither A nor B
    So, I'll ask again : black screen or unresponsive screen ? I know you don't have the black screen but that doesn't necessarily mean that you have the unresponsive screen.
  12. Deactivated User
    Dec 17, 2018
  13. robin143
    Honeycomb Dec 17, 2018
    robin143 , Dec 17, 2018 :
    Hi. I turned ON data saver mode. After that i am still getting notifications of the apps. In actual case the data saver mode should restrict background data. Here it is not happening. Pls help
  14. Dark_Matrix_Guru
    Dark_Matrix_Guru , Dec 17, 2018 :
    after updating to 9.0.2. When I turn my device off and plug in my charger the phone acts as if it is starting up but does not go past the bootloader screen. I didn't have to unplug the charger, hold the power button to shut the phone off, turn the phone back on and let it boot up before I can plug the charger in
  15. R1543487535030
  16. Deactivated User
    Dec 17, 2018
  17. Deactivated User
    Dec 17, 2018
  18. Deactivated User
    Dec 17, 2018
  19. Deactivated User
    Dec 17, 2018
  20. G_Dev_Rajput_TUwT
    Froyo Dec 17, 2018
