685
OxygenOS 9.0.2 OTA for OnePlus 6
  1. Pankaj vedi
    Eclair Dec 28, 2018
  2. UnicornKaz
    Ice Cream Sandwich Dec 28, 2018
    UnicornKaz , Dec 28, 2018 :
    If I were to do some deductive investigating....I would say that under the adaptive battery, you clearly are over hogging your device...without going into further details...30 restricted apps ? ..SMH !! :rolleyes:
  3. UnicornKaz
    I don't know what planet you're from, but in business world, you seriously can't be thinking deadlines are met down to the exact seconds/dates ? :confused::rolleyes:o_O
    Be realistic ... ! :cool:
    ade0410 and peaky blinders like this.
  4. T1544730107388
    Eclair Dec 28, 2018
    T1544730107388 , Dec 28, 2018 :
    Stock OOS 9.0.2. without root. Poor battery? I don't think so. Anybody who cry about battery drain please check aps You have installed.
    ade0410, peaky blinders and aresza20 like this.
  5. T1544730107388
    Eclair Dec 28, 2018
  6. T1544730107388
    Eclair Dec 28, 2018
  7. F_Rushabh_Shah_King_mAWR
    Honeycomb Dec 29, 2018
  8. Jonsnow6099
    Jelly Bean Dec 29, 2018
    Jonsnow6099 , Dec 29, 2018 :
    Not possible on pie...
  9. F_Rushabh_Shah_King_mAWR
  10. jerin.sunil
    Eclair Dec 29, 2018
  11. Jonsnow6099
    Already been explained several times that with pie the recovery partition works differently and the wiping cache in recovery does nothing from pie onwards...for more info on this kindly use google search
  12. jerin.sunil
    Eclair Dec 29, 2018
    jerin.sunil , Dec 29, 2018 :
    okay thanks for the info, bro!
  13. Akshay Chari
    Cupcake Dec 29, 2018
    Akshay Chari , Dec 29, 2018 :
    why no updates after this?
    facing lot of issues with camera
    third party applicantions, which were designed for older version of Android.
    camera closes automatically
  14. RapHassler
    Froyo Dec 29, 2018
    RapHassler , Dec 29, 2018 :
    Hello,
    So, after update it is not necessary to wipe cache in recovery ?
    Sorry, I have my oneplus 6 since 10 days...
    And sorry for my english...
    Enjoy !
  15. Triyank Verma
    Triyank Verma , Dec 29, 2018 :
    Hi,
    I have Oneplus 6 and I'm facing a issue with the camera after the update, sometime when i open the camera and click a photo the application got crashed and it's showing the same issue until remove it from the background and open it again. It mostly happened with the portrait mode and something with the normal mode as well.
    I'm not sure whether it's a update problem or it's just with my device. Does anybody have a suggestion?
  16. Akshay Chari
    Hi.
    Even I am facing the same issue after update.
    And also most of the third party apps which uses camera to take pictures and convert into PDF are not supporting.
    One plus team, please find a solution.
  17. UnicornKaz
    Ice Cream Sandwich Dec 29, 2018
    UnicornKaz , Dec 29, 2018 :
    Please find the answer in the underlined above. :cool:
    Read that over and explain to the community on how this is OnePlus fault ? :eek:o_O
  18. Akshay Chari
    what about Camera Issues??
  19. Jonsnow6099
    Nope...but u can wipe cache of google play services app and other apps which can cause battery drain after updates...
  20. jerin.sunil
    Eclair Dec 29, 2018
    hey man! I haven't faced any crashing of camera. but that doesnt mean it can't happen to you. clear data and cache of your camera or do a factory reset if the problem persists.
    i have had n number of potraits on my phone. no crashing nothing!
