625
  1. Manu J.
    OxygenOS Product Staff Member Jan 1, 2019
    Manu J. , Jan 1, 2019 :
    Hey everyone,
    Update: 9.0.3 Hot Fix release is rolling out.
    We are starting to push the incremental rollout of OxygenOS 9.0.3 for the OnePlus 5 and OnePlus 5T.
    Changelog
    • Hot Fix
      • Fixed connectivity issue with certain third-party Apps
      • Improved stability for Sound settings
      • Stability improvements for the system upgrade
    • System
      • Improved stability for Wi-Fi connection
      • Optimized sRGB display mode
      • Optimized Reading mode
      • Fixed issue with 4G VoLTE toggle missing
      • Fixed random reboots when Screen Casting
    For those who were on previous versions for OnePlus 5 and OnePlus 5T, we appreciate your active feedback for reaching out to us. With your help, we have been able to better optimize and improve several key areas. Thank you for your patience and as always, we look forward to getting your continued feedback in the bug reporting forum here: https://forums.oneplus.com/feedback/.
    As always, this OTA will be incremental. The OTA will reach a small percentage of users today, and we'll begin a broader rollout in a few days.
    Your feedback is appreciated. We may not always be able to respond to every comment in the forums, but please be assured that we take your comments and feedback seriously. Hope you enjoy and let us know how you feel about the update in the comments below.
    Never Settle.
  2. Rakesh_Kumar_T
    Jelly Bean Jan 1, 2019
  3. iNathan
    Gingerbread Jan 1, 2019
    iNathan , Jan 1, 2019 :
    OnePlus 6? *Shrugs*
    Since the 9.0.0 update thread is no longer sticked I have copied FaleshC's FAQ below (sorry to FaleshC if he did repost in this thread, but as it's not stickied it's not on Page 1). I have taken it out of the quote block so the text is expanded by default.
    Answers to the most commonly and repeatedly asked questions!!
    Q. Why is my brightness low after upgrading to Android Pie 9.0?
    A: Google introduced new algorithm for the brightness which will give more control to the user specially in darker environments. The user have to train the brightness preferences for some time in different lighting conditions they use their device so that the device learns it and then adjusts the brightness automatically after that.
    More here:
    https://forums.oneplus.com/threads/behind-the-scenes-how-we-adapted-to-android-pie.909531/
    Thanks to
    @Gary C.
    PS: Use browser to visit the link, Community app is not able to parse the link, throwing error "post cannot be found."
    Q. Where is clear Cache in Android Pie?
    A: Android Pie no longer incorporates the option to clear it in Settings. One has to clear cache by individual app now. However the option is still available in Recovery.
    Cache's Explained Here:
    https://forums.oneplus.com/threads/caches-explained.828298/
    Credits to @elanglois
    Q. Why is there no Digital Well-Being available in OnePlus 5/5T running Pie?
    A: Digital Wellbeing is currently available only to Pixel devices and Android One devices. This may change in near future and OnePlus devices may be added to its supported device list.
    Q.Why is "X" app crashing in my phone running Android Pie?
    A: Many apps are still not updated to support Android Pie, that is the reason they are not able to run in the new OS. Contacting the app developer will be much more helpful.
    Q. My storage is showing extra space after update to Pie, why?
    A: Android Pie also shows the space used by System thus showing the total available storage which was not visible in Oreo.
    Q. Why is my battery draining so fast after update?
    A: This is a major upgrade, you should give it some time to settle before the battery starts working normally. Also battery calibration is always a good way to get most out of it.
    Q. I do not like the new Recents layout, what can i do?
    A: Unfortunately, nothing can be done about it. Its how Google designed it.
    Q. Why don't i see new Pill Navigation Style / New Recents(Task Viewer)?
    A: Sometimes update messes up app data and settings. To solve this clear OnePlus Launcher data and reboot the device. Also check for any updates on Play Store for OnePlus Launcher. Make sure the OnePlus Launcher version is 3.1.xx or above.
    Note: OnePlus 5 does not support new Gesture based Navigation.
    Q. My Play Store is showing "uncertified" after i downgraded to stable, how can i solve it?
    A: Clear Google Play Services data and Play store data and Reboot. Let Play store update automatically and it should change the status to Certified.
    Q. Why cannot i use volume buttons to control the ringtone volume in Android Pie?
    A.
    Google has made change to it, now we can change media volume by default. OnePlus has provided a shortcut to directly go into settings to make it easier to change the ringtone volume.
    Q. Why my Fingerprint does not work, after my phone is in standby for long time?
    A: The Fingerprint service goes to sleep and thus doesn't allow unlocking the phone.
    To avoid this, the current work-around it to turn Off Standby Optimization in Advanced Optimization Battery Settings or wake up the phone using Power button after long standby.
    Q. Why does my Audio Tuner not working on Bluetooth?
    A:
    Bluetooth Audio Tuner support is not yet part of this update, it may arrive in future updates. Its currently in Beta testing for Oneplus 6.
    Q. Why did not i receive the update yet?
    A: Its a staged roll-out already mentioned in announcement post, so wait for your turn to get the notification for the update in your device.
    These are the common questions and their answers, please feel free to add more.
    Anyone can read these and get their answers before making any bug reports.
    Thanks to @camohan for putting the idea forward.
    Hey @camohan if possible please pin this, Thanks.
  4. SwapnilNandre
    Donut Jan 1, 2019
  5. meatandy
    Oreo Jan 1, 2019
    meatandy , Jan 1, 2019 :
    Amazing how quickly things are moving along and it's still 2018 here atm.:p
  6. Priyank Jain1+5T
    Froyo Jan 1, 2019
  7. Shainsha_07
    Ravi BINAVAT likes this.
  8. Tobikage
    Nougat Jan 1, 2019
    Tobikage , Jan 1, 2019 :
    Can't wait for OOS 9.0.2 next week ! :rolleyes:
    Edit :
    It's 2019 and OnePlus still can't roll out an update smoothly without breaking stuff and having to release a HotFix for their HotFix every week. :expressionless:
    Now I can't wait for 9.0.4 to release the week after 9.0.3 is announced. :rolleyes:
  9. Rakesh_Kumar_T
  10. rinku2bapi
    rinku2bapi , Jan 1, 2019 :
    Got 9.0.3. update in India through system update ota..today 1548227444340.jpg
    hope all u get phase wise manner
  11. P1523078522560
    Donut Jan 1, 2019
    P1523078522560 , Jan 1, 2019 :
    i am unable to download any apps from store after update of android 9.0.1 . please help what to do.
  12. sijinjohn
    Eclair Jan 1, 2019
  13. Shainsha_07
  14. Sid_Ck
    Ice Cream Sandwich Jan 1, 2019
    Sid_Ck , Jan 1, 2019 :
    Even after Update to 9.0.1 Twitter,Netflix,Prime music, Yahoo mail & Linked In not working on WiFi but works on Mobile data
    OnePlus - Provide a fix or atleast a workaround
    EDIT - OnePlus has acknowledged this bug and confirmed the fix will be applied in the next update
    Edit 2 - 9.0.2 has fixed this issue, Thanks OP Team for the swift turnaround
  15. rajismine
    Froyo Jan 1, 2019
  16. zer0se7en
    zer0se7en , Jan 1, 2019 :
    But all of the apps you have mentioned has no problems on mine using Wifi or Data.
    nateavi and Ravi BINAVAT like this.
  17. adv.ambatkar
  18. N1513510080942
    Eclair Jan 1, 2019
  19. K1543170665990
    Cupcake Jan 1, 2019
  20. @Nagendra_Sai
    Froyo Jan 1, 2019
    @Nagendra_Sai , Jan 1, 2019 :
    Happy New Year To OnePlus and OnePlus Community Numbers
    OnePlus gave me New Year gift to me that was very nice [e]1f44c[/e] [e]1f618[/e]
    That's Nothing But Software Update 9.0.1
    Thank You OnePlus for ur Beautiful Gift
    Love You OnePlus
