625
  1. rainderzzz
    Froyo Jan 1, 2019
    rainderzzz , Jan 1, 2019 :
    clear data your oneplus launcher bro. update from playstote. done.
    rinku2bapi likes this.
  2. rinku2bapi
    Gingerbread Jan 1, 2019
  3. N1524300102050
    Donut Jan 1, 2019
    morikee likes this.
  4. yogeshchandra65
    Eclair Jan 1, 2019
    yogeshchandra65 , Jan 1, 2019 :
    which location did you use?
  5. FiDuS
    Froyo Jan 1, 2019
    V1542277143658 likes this.
  6. Icecreamypie
    Ice Cream Sandwich Jan 1, 2019
  7. piko12
    Donut Jan 1, 2019
    piko12 , Jan 1, 2019 :
    where is 9.0.1.? i have stil 9.0.0..how to upgrade tell vpn name..no upgrade for 5?.
    O1518190482263 likes this.
  8. rainderzzz
    Froyo Jan 1, 2019
    locate your oneplus launcher in apps in settings. You use android and don't know about it come on bro
  9. rinku2bapi
    rinku2bapi , Jan 1, 2019 :
    no option to clear data bro
  10. SevenOptimus
    Froyo Jan 1, 2019
    SevenOptimus , Jan 1, 2019 :
    Go to Settings > Apps > Application List > OnePlus Launcher. Press "Clear Data", and also press "Uninstall Updates". Then go to the Play Store and search for "OnePlus Launcher". Select "Uninstall", then after it's done, select "Install" and it should work.
  11. rinku2bapi
    ok
  12. FiDuS
    Froyo Jan 1, 2019
    Krysleg17300Fr likes this.
  13. rainderzzz
    Froyo Jan 1, 2019
  14. rinku2bapi
    thank u bro ..got it
  15. lmigueldias
    Eclair Jan 1, 2019
    lmigueldias , Jan 1, 2019 :
    Hello all.
    If on beta I must reinstall stable to get this update?
    Or does he pull out from beta too?
  16. D1516421053706
    Donut Jan 1, 2019
    D1516421053706 , Jan 1, 2019 :
    I'm facing the same issue. Unable to update any apps on Play store post 9.0.1 update...
  17. PrismereKnight
    Donut Jan 1, 2019
    PrismereKnight , Jan 1, 2019 :
    Same here. Did you find a fix?
    Sid_Ck likes this.
  18. Sid_Ck
    Sid_Ck , Jan 1, 2019 :
    No sir , I suggest you also to raise bug too on the same... tried a lot of things on phone and WiFi router unable to find any solution
    PrismereKnight likes this.
  19. angourakis
    Froyo Jan 1, 2019
    angourakis , Jan 1, 2019 :
    A full wipe is required when going from Beta to Stable.
    Just download the full zip and flash it on recovery. Wipe data and cache before rebooting to the system.
    If you want to do it via OTA, then yes, you have to reinstall the Stable version: https://www.oneplus.com/support/softwareupgrade and wait for a notification to pop up (or, you know, you can search for a direct link to the full zip and avoid having all this work)
    Probably issues with the apps, not with the Pie update. Try cleaning the apps data.
  20. lmigueldias
    Eclair Jan 1, 2019
    Thanks for the reply.
    After seeing some bugs reported here with last stable I guess I'll just wait.
