625
  1. Rajivrj
    Cupcake Jan 5, 2019
  2. D_24
    Gingerbread Jan 5, 2019
    D_24 , Jan 5, 2019 :
    Is the camera shutter sound bug fixed in this version?
  3. S1530692221127
    Eclair Jan 5, 2019
    S1530692221127 , Jan 5, 2019 :
    Can you share the changelogs.
  4. cybersa
    Honeycomb Jan 5, 2019
    cybersa , Jan 5, 2019 :
    No. Shutter sound is still there.I tired toggling between on and off.
    I hope official 9.0.2 update will fix this issue.
  5. miromir2217
    Cupcake Jan 5, 2019
    miromir2217 , Jan 5, 2019 :
    Are all the people that are having issues on 5, not 5T? I am on 5T on 9.0.0 and have not experienced anything significant rather than laggy scrolling in Google Play.
    I got the up through VPN to Germany
  6. A1517417365290
    Cupcake Jan 5, 2019
    A1517417365290 , Jan 5, 2019 :
    after this update my op5 parallel space what's app not download and shown any pictures and videos . I clear cache and restart but no response is it any problem
  7. cybersa
    No, i didn't get any changelog from OP team. They asked me to test the WiFi issue. Thats it.
  8. Chetan@1991
    Cupcake Jan 5, 2019
  9. S1530692221127
    Eclair Jan 5, 2019
    Ok, I am currently on 9.0.1, and I am facing issues in whatsapp voice call on wifi, the other user gets my voice delayed but I am able to receive their voice instantly, although video call works fine.
  10. cybersa
  11. salil.dubey20
    Cupcake Jan 5, 2019
    salil.dubey20 , Jan 5, 2019 :
    the gaming mode doesn't work at all after the update. also sliding down the notification bar while being on calls is impossible after the 9.0.1 update. does anyone else have similar issues?
  12. S1530692221127
    Eclair Jan 5, 2019
  13. S1530692221127
    Eclair Jan 5, 2019
    For me gaming mode is working fine, but for sliding down during call I have to drag it down completely then only it works, not soo smooth though.
    salil.dubey20 likes this.
  14. salil.dubey20
    Cupcake Jan 5, 2019
    yes short slides don't work and look buggy. the gaming mode on a few apps just doesn't work at all.
  15. Harshag11
    Froyo Jan 5, 2019
    Harshag11 , Jan 5, 2019 :
    +1
  16. mukeshj160
    Cupcake Jan 5, 2019
  17. Carfs
    Froyo Jan 5, 2019
    Carfs , Jan 5, 2019 :
    So far so good, but:
    I am using Filmic Pro in my 5t. It works perfectly, but can't select over 30 fps, no matter what resolution selected. Thought this update would sort it out, but no, it doesn't.
    I've emailed Filmic Pro and the answer I got was
    "Unfortunately OnePlus have not made 60fps available to third-party developers and reserve it for their own native camera app through the use of private APIs. You won't find a third party app that supports 60fps until OnePlus address the issue by way of a system update that opens up this functionality.
    If OnePlus opens up this possibility in the future, we will be quick to bring support for 60fps on your device."
    Trust you sort this out shortly - besides sounding like an Apple policy (!!!), fact is that this kind of constraint doesn't happen with iPhone, Samsung or others....
    Do look forward to your feedback on this for which I thank you in advance.
    Qwert Luiop and karpo3 like this.
  18. MarkyPancake
    MarkyPancake , Jan 5, 2019 :
    I don't have a third-party camera app on my OP5 to test fps, but on my 3T, the ported Google Camera can be set and captures video at 60fps.
    Carfs likes this.
  19. F_Sumeet_Singh_EIqA
    Cupcake Jan 5, 2019
  20. Kamal Hans
    Ice Cream Sandwich Jan 5, 2019
    Kamal Hans , Jan 5, 2019 :
    Then plz consider using the Oxygen updater app from the play store, but note & carefully follow the method to update as given in the app.
