625
  1. Vladut123
    Honeycomb Jan 5, 2019
    Vladut123 , Jan 5, 2019 :
    your guess is that oxygenos 9.0.2 for oneplus 5 will be available today or next week?
  2. Kamal Hans
    Ice Cream Sandwich Jan 5, 2019
    Kamal Hans , Jan 5, 2019 :
    You could always consider using the Oxygen updater app from the play store if you do not wish to wait for the OTA. In case you do , plz follow the steps carefully. Plz google on how to use the app properly first.
  3. Kamal Hans
    Very difficult to predict,sir.
    It will take time for sure.
  4. R1546621747488
    Donut Jan 5, 2019
    Qwert Luiop likes this.
  5. Q1545504703112
    Gingerbread Jan 5, 2019
    Q1545504703112 , Jan 5, 2019 :
    I doubt it will take long as many people's phones have become unusable after the update. OnePlus should be quite quick to release a bug fix update
    ChinaMarius likes this.
  6. H1517568106406
    Cupcake Jan 5, 2019
  7. MarkyPancake
    MarkyPancake , Jan 5, 2019 :
    I've found a solution to the default volume behaviour, an app called Button Mapper, but you need the pro version. It enables you to change the Pie volume control back to how it has worked for years. So, ringer by default and media when watching content.
    The annoying thing is, it shows that the on-screen volume UI can accommodate multiple volume controls, but there's no way to set this behaviour or pull out these controls currently in Pie.
  8. F_Waldar_Richerd_Rajaiah
    Cupcake Jan 5, 2019
    F_Waldar_Richerd_Rajaiah , Jan 5, 2019 :
    I updated pie 9.0 by using VPN ...shall I get a Random updates after using VPN...becz still I didn't receive 9.0.1 ..I really worried about it..give suggestion pls
  9. G_rohit_patil_js
    Cupcake Jan 5, 2019
  10. SAJANSAYAN
    Froyo Jan 5, 2019
  11. F_Waldar_Richerd_Rajaiah
    Cupcake Jan 5, 2019
  12. PokiX
    Jelly Bean Jan 5, 2019
    PokiX , Jan 5, 2019 :
    A Virtual Private Network creates a tunnel between you and exit of VPN so that you appear to be connected from this or that country.
    So you just bypass country restriction and the rest is completely transparent. If next update is available to your country, you'll get a notification, otherwise you can use again a VPN.
  13. G_nadeem_chouhan_efHO
    Cupcake Jan 5, 2019
  14. W1519306614247
    Cupcake Jan 5, 2019
    W1519306614247 , Jan 5, 2019 :
    after upgrade to android 9 Pie the camera in my 5T, does not respond after a couple of hours sleep/not in use. have to restart the phone to activate it. how can this be fixed?
  15. M1536158392307
    Cupcake Jan 5, 2019
  16. P1512569276852
  17. G_rohit_patil_js
    Cupcake Jan 5, 2019
  18. F_Ravi_Mangloriya_QRMN
    Cupcake Jan 5, 2019
  19. F_Kiran_Sreekandan_iXTl
    Eclair Jan 5, 2019
    F_Kiran_Sreekandan_iXTl , Jan 5, 2019 :
    That is good news..!! The update has made my phone slow and laggy.
    M1536158392307 likes this.
  20. M1536158392307
    Cupcake Jan 5, 2019
