623
  1. Rakesh_Kumar_T_
    Jelly Bean Jan 6, 2019
    Rakesh_Kumar_T_ , Jan 6, 2019 :
    download a VPN app, and connect to either Germany or Canada, but in case of this update I don't think VPN works, try Oxygen updater app from playstore
  2. sachkharb
    Ice Cream Sandwich Jan 6, 2019
    sachkharb , Jan 6, 2019 :
    Do a completely factory reset including delete storage... N dont forget to take a backup before
  3. sachkharb
    No... OP5 is compatible that's why they rolled it out. I am enjoying pie on my OP5
  4. Gautham.2001
    Gingerbread Jan 6, 2019
  5. X1521566754321
    Eclair Jan 6, 2019
    X1521566754321 , Jan 6, 2019 :
    I didn't get the update 9.0.1.
  6. Tcat007
    Honeycomb Jan 6, 2019
    Tcat007 , Jan 6, 2019 :
    You might trying clearing cache and data in settings (if you can get there without crashing). You'll have to reselect your settings choices. If that doesn't work you need a clean flash.
  7. RakeshZn
    RakeshZn , Jan 6, 2019 :
    i think they stopped rolling the updates due to issues
  8. C1522817504370
  9. tsakdion
    Cupcake Jan 6, 2019
    tsakdion , Jan 6, 2019 :
    There?
  10. nikskrish
    Donut Jan 6, 2019
    nikskrish , Jan 6, 2019 :
    u will get it soon.. I got it on 31st night ... direct through OTA..
  11. C1522817504370
    C1522817504370 , Jan 6, 2019 :
    r u staying in India
  12. X1521566754321
    Eclair Jan 6, 2019
    my version is 9.0.0 .
  13. shivani_3
    Cupcake Jan 6, 2019
  14. itsakhil5
    Cupcake Jan 6, 2019
    itsakhil5 , Jan 6, 2019 :
    After this update my phone is turning off automatically and very frequently after going to sleep. please fix it.
  15. Tcat007
    Yes, try just cache first, then both of that doesn't work.
  16. tsakdion
    Cupcake Jan 6, 2019
    it's just do same things..so I must do factory reset? [e]1f614[/e]
  17. Khems91
    Khems91 , Jan 6, 2019 :
    Now we have "Do Not Disturb" toggle as QS tile, I was really tired by sliding alert slider all the time whenever i need to keep my device silent.
    So many thanks for this.
  18. Tcat007
    Download from Playstore.
    Open it.
  19. Khems91
    You don't have to wait, just download full rom and flash.
  20. C1522817504370
    do we have to flash to upgrade . if we use oxygen updater
