624
  1. L1534314527088
    Cupcake Jan 7, 2019
    L1534314527088 , Jan 7, 2019 :
    my phone gets hangs every app after update. but some time it's fine using. y so ???
    main I did not like the layout for closing or switching from application.
  2. Raj1007
    Cupcake Jan 7, 2019
  3. L1534314527088
    Cupcake Jan 7, 2019
  4. G_Bapu_Hirave_Dtog
    Cupcake Jan 7, 2019
  5. Raj1007
    Cupcake Jan 7, 2019
    Raj1007 , Jan 7, 2019 :
    how can i download bro !
  6. L1534314527088
    Cupcake Jan 7, 2019
    go settings and check for updates. it will be there
  7. Tcat007
    Honeycomb Jan 7, 2019
  8. Sureshavs
    Cupcake Jan 7, 2019
    Sureshavs , Jan 7, 2019 :
    till i have not received the pie update... what's the problem..i am eagerly waiting for it.
  9. Nithin RJ
    Froyo Jan 7, 2019
    Nithin RJ , Jan 7, 2019 :
    Wait.It will show up sooner or later.Show some patience,retard!
    fazerboy0_3 likes this.
  10. Sureshavs
    Cupcake Jan 7, 2019
    pie rolled out on 25 dec on OP5 & 5T devices...but after two weeks also we are not getting it... what's the patience showing in this..what do u mean by sooner or later..is this a way to reply..
    shriman_shubham_g likes this.
  11. karankapoor564
    Froyo Jan 7, 2019
  12. G_Jaspreet_Singh_zNVl
    Cupcake Jan 7, 2019
    G_Jaspreet_Singh_zNVl , Jan 7, 2019 :
    I am still finding issue updating my phone. I have tried using VPN and direct search for updates through the settings menu.
    I am unable to find any updates. Attached is the status. Please assist what should I do here.
    Thanks.
  13. BHAUMIK.T007
    Eclair Jan 7, 2019
  14. Tcat007
    Tcat007 , Jan 7, 2019 :
    It rolled out on the 25th, why haven't you downloaded it and installed it? The OTA obviously has issues, so they are working on it. If you manually install and know what you're doing, there are no issues at all. Otherwise, could be a day could be 2 more weeks... it's not up to anyone here. Lots of posts on where and how to get it.
  15. swaraj_c.r.
    Gingerbread Jan 7, 2019
    swaraj_c.r. , Jan 7, 2019 :
    I have one doubt , can I delete the zip installation package after update. I updated using oxygen updater.
  16. Tommyd78
    Eclair Jan 7, 2019
  17. Nithin RJ
    Froyo Jan 7, 2019
    Cupcakes like u dont know what the developers are going through.They come up with a stable build roll it out to some users and soon they find users reporting a critical bug that may need weeks or upto a month to fix.This is not the first time an update is delayed.5.1.7 ; also took a month to reach.
    AnimatedKiller likes this.
  18. jonchin95
    Donut Jan 7, 2019
    jonchin95 , Jan 7, 2019 :
    NETFLIX ON ONEPLUS 6T. NO VIDEO. BLACK SCREEN. ONLY AUDIO & SUBTITLES.
    This is completely unacceptable. Netflix literally cannot play any videos at all, I've seen multiple similar threads on this and there hasn't been a fix on this from OnePlus! This is basic and unexpected of a high-end phone like a OnePlus 6T.
    I've tried clearing the cache of Netflix, restarting my phone, reinstalling the app, checked to be sure that Color Correction is deactivated. None have resolved the issue.
    Netflix works perfectly fine on my iPad and other Android devices.
    Anyone else struggling with this? ONEPLUS PLEASE ADDRESS THIS.
    Thank you.
  19. Nithin RJ
    Froyo Jan 7, 2019
    Pie update 11? WTH is that?If u want it now,pls use a vpn!
  20. Sureshavs
    Cupcake Jan 7, 2019
    r u a developer???
