625
  1. DMX72
    Gingerbread Jan 8, 2019
    DMX72 , Jan 8, 2019 :
    FFS PEOPLE!!
    Please read at least some of the recent posts regarding what's going on with the update(s) before posting the same old crap time and time again. It's like observing a bunch of 4yr olds in kindergarten.
  2. slipd
    Eclair Jan 8, 2019
    slipd , Jan 8, 2019 :
    I'm in the UK and Oxygen Updater/System Updater is still showing 9.0.0, which is definitely best avoided imo.
    Be interested to hear how you get on, which vpn you use etc.
  3. DMX72
    Once 9.0.0 is installed via Oxygen Updater 9.0.1 will appear in the app
  4. slipd
    Eclair Jan 8, 2019
    Ah, okay... and is there much benefit of 9.0.1 over the initial release? I had issues with Bluetooth and the Play Store updating on 9.0.0.
  5. chewsifer
    Froyo Jan 8, 2019
    chewsifer , Jan 8, 2019 :
    Quote - DMX72
    FFS PEOPLE!!
    You're not giving the kindergarteners enough credit or these people too much
  6. DMX72
    I had the same issues as yourself but everything is running fine on 9.0.1 except for the Google assistant where the mic does not work. Apart from that very smooth and responsive.
  7. DMX72
    Then again maybe Google can't understand my Scottish accent haha
  8. slipd
    Eclair Jan 8, 2019
    Cool, thanks. And did you do a clean/dirty install? I was thinking of doing a dirty to 9.0.1 and then doing a factory reset :)
  9. jsohamm
    Froyo Jan 8, 2019
  10. DMX72
    My Bootloader is locked so was just a case of moving the zip file to root directory then into recovery mode then install. And yeah a factory reset also. Full instructions below
    Download the full zip/incremental OTA from the download section above and place it in the root of your internal memory
    Reboot to stock recovery > Shutdown device > Press Volume Down + Power buttons together
    Select language > Install menu > Install from internal > Select the full zip > Flash
    After a successful flash > Wipe cache
    Reboot
    Factory reset if desired
  11. Jaweedtameem
    Donut Jan 8, 2019
    Jaweedtameem , Jan 8, 2019 :
    my op 5t is crashing a lot
    really need the update
    it's been couple of days since it has been released
    don't know when I'll receive it
  12. X1511276552576
    Cupcake Jan 8, 2019
  13. jmarks
    Honeycomb Jan 8, 2019
  14. akshit1905
    Cupcake Jan 8, 2019
    akshit1905 , Jan 8, 2019 :
    My OnePlus 5's battery is draining faster than usual. Is anyone else facing the same issue?
    akshay.ak1 likes this.
  15. jmarks
    jmarks , Jan 8, 2019 :
    Do nothing. Stay in Oreo.
    X1511276552576 likes this.
  16. Romanelo
    Froyo Jan 8, 2019
  17. iNathan
    iNathan , Jan 8, 2019 :
    I believe the update has been pulled due to bugs with Android Pie.
    I don't know of a time frame sorry, they are testing 9.0.2 but that's not publicly available.
    Runnry likes this.
  18. C1546977030283
    Cupcake Jan 8, 2019
  19. F_Maheedhar_Puranam_QvJs
    Eclair Jan 8, 2019
  20. Runnry
    Eclair Jan 8, 2019
    Runnry , Jan 8, 2019 :
    From time to time, while browsing the Web, the phone has a falling frame rate, this happens a few times and for a very short time.
