625
  1. kingsukpasari
    Cupcake Jan 9, 2019
  2. Peervandoorn
    Froyo Jan 9, 2019
    giovannichiappetto likes this.
  3. Tcat007
    Honeycomb Jan 9, 2019
    Tcat007 , Jan 9, 2019 :
    Dirty flash file from Oxygen Updater or XDA.
  4. Android-Andi
    Jelly Bean Jan 9, 2019
    Android-Andi , Jan 9, 2019 :
    sounds like the right Version for ETA screamer ;)
    davkos and mischa1981 like this.
  5. Bullo Oka
    Bullo Oka , Jan 9, 2019 :
    Any work around to make these black (Toggle greyish black area).
    without rooting the device.
  6. Tcat007
    These what? To make the red, black, just pick black as the accent. Otherwise I have no clue what you're talking about.
  7. Bullo Oka
    those greyish black area to deep black like in settings.
  8. Tcat007
    Then no, not without root and substratum. Mine's translucent.
  9. Z3ust3x
    Cupcake Jan 9, 2019
  10. AndreRic182
    Cupcake Jan 9, 2019
    AndreRic182 , Jan 9, 2019 :
    When I answer a message from the notification center using the swipe down ( fast answer ), the notification doesn't disappear. Instead, the notification center shows my answer too as a notification.
    This problem showed even when I used the "sign as read" button. It didn't work.
    Hopeful to see this solved.
    Thanks
  11. suraj_offl
    Gingerbread Jan 10, 2019
    suraj_offl , Jan 10, 2019 :
    it's a feature introduced by Google in pie.
    AndreRic182 likes this.
  12. Luis Carrasco
    Cupcake Jan 10, 2019
  13. Waveform Modifier
    Marshmallow Jan 10, 2019
    meatandy likes this.
  14. g.fiad
    Eclair Jan 10, 2019
    g.fiad , Jan 10, 2019 :
    This is happening on 9.0.0 or the 9.0.1 update? I'm having issues with my Fitbit Versa in the 9.0.0. Thanks
  15. g.fiad
    Eclair Jan 10, 2019
    Me brow, I'm on the 9.0.0 having issues with Bluetooth connectivity.
  16. Dragos Roos
    Eclair Jan 10, 2019
    Dragos Roos , Jan 10, 2019 :
    I'm still in 8.1.0
  17. Luis Carrasco
  18. Waveform Modifier
    Waveform Modifier , Jan 10, 2019 :
    But it's true. OnePlus never announce any dates to updates, ever.
    eye842 and meatandy like this.
  19. g.fiad
    Eclair Jan 10, 2019
    This print came from a Fitbit pairing mode?
  20. I1546126731590
    I1546126731590 , Jan 10, 2019 :
    tem um problema com o destravamento meu filho descobriu que apertando no leitor digital 3 vezes e puxando do rostinho jogando para cima destrava o telefone. sistema de segurança falho.
