625
  1. luciano75
    Eclair Jan 1, 2019
  2. G_Mere_Puff_dalc
    Froyo Jan 1, 2019
    G_Mere_Puff_dalc , Jan 1, 2019 :
    I was thinking about OnePlus launcher for OnePlus 5 it's suck. please give an update for launcher for OnePlus 5
  3. SevenOptimus
    Froyo Jan 1, 2019
  4. DavidYoho
    Froyo Jan 1, 2019
  5. Katrina_Brennan
    Cupcake Jan 1, 2019
  6. ptlyadvendra
    Eclair Jan 1, 2019
    crzfyr likes this.
  7. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Jan 1, 2019
    DavidYoho likes this.
  8. Q1545504703112
    Honeycomb Jan 1, 2019
    Q1545504703112 , Jan 1, 2019 :
    9.0.0 came out on Xmas day in the UK, but it disappeared a couple days after, if you check your settings app 9.0.1 should be available to download
  9. D1533851859593
    Eclair Jan 1, 2019
    D1533851859593 , Jan 1, 2019 :
    I'm quite a confused about the updating using Oxygen Updater...
    could you please direct steps by step.
    the instructions given thru the App is confusing.
  10. Katrina_Brennan
    Cupcake Jan 1, 2019
    Katrina_Brennan , Jan 1, 2019 :
    I've checked and not had anything.
  11. mohitnagpure
    Cupcake Jan 2, 2019
  12. Bob8
    Froyo Jan 2, 2019
    Bob8 , Jan 2, 2019 :
    got it about this time new years day in UK. no VPN needed.
  13. Katrina_Brennan
    Cupcake Jan 2, 2019
  14. Bob8
    Froyo Jan 2, 2019
  15. SevenOptimus
    Froyo Jan 2, 2019
    SevenOptimus , Jan 2, 2019 :
    As I said earlier, you can update manually. Download links are https://otafsg1.h2os.com/patch/amaz...43_OTA_043_all_1812290042_aeba6593cd82c95.zip for the 5T and http://otafsg1.h2os.com/patch/amazo...s5Oxygen_23_OTA_043_all_1812290030_0d3042.zip for the 5.
    (To install on a non-rooted device, simply place the ZIP file in the root of internal storage, then go to Settings > System updates, press the cog in the top-right corner, then select Local upgrade and follow the instructions.
    To install on a rooted device, see the flashing instructions at https://forum.xda-developers.com/oneplus-5t/how-to/official-oxygenos-4-7-2-7-1-1-ota-t3709265)
    doekus and bertans like this.
  16. Tcat007
    Honeycomb Jan 2, 2019
    Tcat007 , Jan 2, 2019 :
    What shutter sound? This has been mentioned so many times. Some countries/sims require the sound, so you can't disabled it. Mine had no sound in USA.
  17. P1528194180841
    Cupcake Jan 2, 2019
  18. D1533851859593
    Eclair Jan 2, 2019
  19. MKT_IRFAN3735
    Jelly Bean Jan 2, 2019
  20. iNathan
    Gingerbread Jan 2, 2019
    iNathan , Jan 2, 2019 :
    If you're in India then you're not allowed to disable the camera shutter sound.
    Sourav Kumar Sahu likes this.
