625
  1. Aliaksandr_Pedzko
    Cupcake Jan 11, 2019
    Aliaksandr_Pedzko , Jan 11, 2019 :
    The same for Belarus - update 9.02 is not available
  2. KRZYSZTOF_BEDZISZ_BEDA
    Eclair Jan 11, 2019
    ChinaMarius likes this.
  3. VangelisKps
    Froyo Jan 11, 2019
    VangelisKps , Jan 11, 2019 :
    From 9.0.0 to 9.0.2 via OTA (VPN Germany). Everything is working and battery is great on my 5T.
  4. KRZYSZTOF_BEDZISZ_BEDA
    Eclair Jan 11, 2019
  5. odilovuz
    odilovuz , Jan 11, 2019 :
    I am a beta OS user. still can't download the update. even with VPN. Is there any other way to do it??
  6. GUKKE_XIV
    GUKKE_XIV , Jan 11, 2019 :
    will it have some bad side effects?
  7. KRZYSZTOF_BEDZISZ_BEDA
    Eclair Jan 11, 2019
  8. odilovuz
    how did you manage to back to stable version from beta version?
  9. gorneanu
    Gingerbread Jan 11, 2019
    gorneanu , Jan 11, 2019 :
    I have spoken to 3-4 users on the forum and another 1-2 which are my friends. Nobody has received any update. Everybody is on 5.1.7 which is an update from 4 months ago.
  10. GUKKE_XIV
    i can't download the 9.0.2 version, only the 9.0.0
  11. gorneanu
    I'm pretty sure that you are a beacon of wisdom down these forums. Dumb is when you take everything exactly like it's thrown at you. Best of luck with those VPNs and stuff.
  12. proharsh1
    proharsh1 , Jan 11, 2019 :
    yess soon
  13. KRZYSZTOF_BEDZISZ_BEDA
    Eclair Jan 11, 2019
  14. proharsh1
    A bug they recognised and its solution.
  15. S1545758374864
  16. proharsh1
    mostly indian law. Cannot take photos "SECRETLY"
  17. S1545758374864
  18. rajkumar5t
    rajkumar5t , Jan 11, 2019 :
    first time i try to upgrade to 9.0.2 the update was about 198 mb and it failed while upgrading now same upgrade is showing 1798 mb should i upgrade or not
  19. G_Venu_Acharya_iDlE
  20. AnimatedKiller
    Honeycomb Jan 11, 2019
    AnimatedKiller , Jan 11, 2019 :
    It's not a trivial thing per se.
    The question you're asking the community has been answered tremendous number of times in the past.
    And I wasn't being rude, there's a fine gap between being rude and sarcastic.
    Offensively you're bringing "moms" in between, seems like I'll be a 60 year old here but you're being a kid here.
    A simple Google search would actually help you too:
    And all your further comments show it takes one single answer which are facts imo to trigger you so quickly. You started going through my entire profile and Display Picture to add more to your judgement comments. Aur bhai hindi toh badiya bol leta hai, Andrew Garfield is an actor in film industry, so I'm judging his name by referencing Spider-Man, than you. So before jumping to conclusions and trying to act "smart", I'd request you to serve yourself with research materials first and then continue arguing over your point.
