625
  1. AnimatedKiller
    Honeycomb Jan 11, 2019
    AnimatedKiller , Jan 11, 2019 :
    I actually explained you regarding the hardware incapability and also the better way to use RAW capturing in order to replace Nightscape
  2. Andrew Garfield
    Ice Cream Sandwich Jan 11, 2019
    Andrew Garfield , Jan 11, 2019 :
    AnimatedKiller
    I actually explained you regarding the hardware incapability and also the better way to use RAW capturing in order to replace Nightscape​
    Yeah i went through the entire comment but that one caught my attention.
  3. DogeAlpha
    DogeAlpha , Jan 11, 2019 :
    Romanian here.
    I'm currently on 9.0.0 but I updated through VPN (Germany) on 26th December before they presumably stopped the rollout otherwise I would have missed it probably.
    You will eventually receive an update that will take you from 5.1.7 straight to 9.0.2
  4. Andrew Garfield
    DogeAlpha
    Romanian here.
    You are right . I got 9.0.2 update without using vpn . I was on 9.0
  5. Andrew Garfield
    So basically there isn't much difference between nightscape and pro mode?
  6. kailashrathii
    Cupcake Jan 11, 2019
    kailashrathii , Jan 11, 2019 :
    while udpating using oxygen update do I need to back up the data or there will be no loss of data
  7. AnimatedKiller
    I can't exactly agree to that because most manufacturers as of Pie Update have allowed users to disable the Shutter Sound. And the issue carries over to third party applications like Snapchat and Instagram too. So maybe OnePlus needs to tweak some things there.
    G_Harsh_Chheda_XWud likes this.
  8. Trevor.Hawkes
    pingling, luhhfe, PokiX and 1 other person like this.
  9. Ashwin_cs
    Froyo Jan 11, 2019
    Ashwin_cs , Jan 11, 2019 :
    after update even though notification is blocked still I am getting notifications. anyone facing same issues?
  10. AnimatedKiller
    Nightscape will automatically tweak the photo to add more brightness and contrast. Pro Mode is when you tweak settings related to shutter speed and ISO.
    A lower shutter speed of 5 and a varying ISO can give you great photos. For example:
    This was taken at 4AM night of New Year.
    Only one far light source, where I kept shutter speed to 5 seconds and maintained ISO at 800-1000.
    With good adjustments you can avoid noise too.
    RAW capturing can be used and edited in Snapseed or Lightroom CC as well.
    OnePlus actually made a camera this good that you can play around with settings that challenge Nightscape photography too
  11. zulrakz
    Donut Jan 11, 2019
  12. PokiX
    Jelly Bean Jan 11, 2019
    PokiX , Jan 11, 2019 :
    Any data should always be backed up. This is decorrelated from an update.
    What happens if one morning the device is dead. Or lost, stolen,.. ?
  13. F_శ్రీనివ
  14. hitmen7
    Froyo Jan 11, 2019
  15. luhhfe
    luhhfe , Jan 11, 2019 :
    I still 5.1.7. Why?
  16. C1547211022724
  17. PokiX
    You are still on Oreo?
  18. C1547211022724
  19. shyam069
    shyam069 , Jan 11, 2019 :
    I have still not received Android P update in my one plus 5T when I'm most probably to get it??
  20. C1547211022724
    C1547211022724 , Jan 11, 2019 :
    it's been 25 days still haven't got the update and these guys are getting 9.0.2
