625
  1. axbrandao
    Gingerbread Jan 11, 2019
    axbrandao , Jan 11, 2019 :
    Yes!!! Never Settle
  2. Multiplatform Gamer
    Ice Cream Sandwich Jan 11, 2019
    Multiplatform Gamer , Jan 11, 2019 :
    what about general random reboots when the phone is sleeping or when using apps like facebook or messenger? i sent logs three weeks ago for that and despite this i still have random reboots generaly using the phone. also my phone random reboots every time i reboot it. after doing a factory reset, the boot logo froze and it random reboot three times before it was able to go to the setup then, the setup random reboot two times before i could start using the phone.
  3. G_Shivanand_Ayatti_cKil
    Eclair Jan 11, 2019
  4. sesenbinoguz
    Donut Jan 11, 2019
  5. Clin10
    Cupcake Jan 11, 2019
  6. kr.rahul27
    Honeycomb Jan 11, 2019
    kr.rahul27 , Jan 11, 2019 :
    whats your problem be in your limit na i'm asking to community not to u
  7. harsha.yarabarla
    harsha.yarabarla , Jan 11, 2019 :
    after replying to WhatsApp / telegram messages from notification , the notification will not dismiss automatically which used to happen in Oreo. is this some kind of feature in pie ? It's very frustrating to dismiss it manually.
  8. Clin10
  9. aadis04
    Froyo Jan 11, 2019
    aadis04 , Jan 11, 2019 :
    Phonepe app isn't getting installed in oxygen os 9.0.2. any1 else facing this issue??
  10. NishanthJ
    Donut Jan 11, 2019
    NishanthJ , Jan 11, 2019 :
    can u explain procedure
  11. Partha Kamilya
    Partha Kamilya , Jan 11, 2019 :
    guys, not getting any update after 5.1.7. i am from Kolkata, India
    do i need to wait more or is there any options to receive the update.
  12. Clin10
    Clin10 , Jan 11, 2019 :
    Download any vpn from play store... Example thunder VPN then go to options and manually select Germany vpn and select connect....once connected go to system updates and check for updates.....there you go!
    NishanthJ likes this.
  13. Tcat007
    Tcat007 , Jan 11, 2019 :
    Phone does, not phonepe.
  14. NishanthJ
    Donut Jan 11, 2019
    guys it's working for me in Canada
  15. sunilkumargoudkalli
    Froyo Jan 11, 2019
  16. G_Rupesh_Rathaur_gMNb
    G_Rupesh_Rathaur_gMNb , Jan 11, 2019 :
    internet is slower aftet the update. some apps are not able to perform due to slow internet. neither mobile data nor wifi is as fast as it used to be. processing is fast but apps are slow because internet is slow so every app finding it hard to run.
  17. G_vatsal_pancholi_EDZQ
    Donut Jan 11, 2019
    G_vatsal_pancholi_EDZQ , Jan 11, 2019 :
    after updating my phone to android pie. I'm having difficulty to login to our campus wifi. the wifi has 2 stages of login, one thru the normal user id and password, the other stage is logging in thru the 'sign in to wifi' option. the first stage works fine, but the second stage doesn't load at all. I get stuck to the page without connectivity. is there any solution to this problem?
    thanks in advance.
  18. vasanth88j
    Froyo Jan 11, 2019
    vasanth88j , Jan 11, 2019 :
    download oxygen updater from google playstore and download the update from it.
  19. sesenbinoguz
    Donut Jan 11, 2019
    sesenbinoguz , Jan 11, 2019 :
    its fixed 9.0.2
  20. G_vatsal_pancholi_EDZQ
    Donut Jan 11, 2019
