625
  1. P1518424954324
    Cupcake Jan 11, 2019
    P1518424954324 , Jan 11, 2019 :
    hi I am from India and I haven't received any update for 9.0.0 or above on My OnePlus 5T !!!
    what to do?.
    how much time it will take ???
  2. Q1518162216468
    Donut Jan 11, 2019
    Z1531301447301 likes this.
  3. SudebCena
    Donut Jan 11, 2019
    SudebCena , Jan 11, 2019 :
    Where is the 60fps option in OnePlus 5T after the Hotfix?
    P. S. Found them after a while. At first there was only 720p & 1080p options. Now all 4 are there.
    RoyxD4 likes this.
  4. Matteo333
    Donut Jan 11, 2019
    Matteo333 , Jan 11, 2019 :
    to all who didnt received the Update yet and are concerned about it: please use oxygen updater from Playstore. simple and comfortable solution.
  5. danilo.tsrm
    danilo.tsrm , Jan 11, 2019 :
    Is that normal that my OnePlus 5t is not receiving any updates? It's still with Android 8.1.0 and even I try to "check for updates", nothing happens, on the screen the message "your system is up to date"
  6. Tcat007
    Honeycomb Jan 11, 2019
    Tcat007 , Jan 11, 2019 :
    See if Oxygen updater gives you the same message.
  7. M1526418706179
    M1526418706179 , Jan 11, 2019 :
    Hello. I've a question about the notification bar ? why now when it open, the size is double ? one line with hour and a second with date ?
    notifications closed
    notifications opened
    is it an evolution of android pie ?
  8. Tcat007
    It's always had one line in status bar, 2 lines if qs is pulled down.
  9. Y1547127163469
  10. F_Shon_Elliott_cbWP
    Donut Jan 11, 2019
    F_Shon_Elliott_cbWP , Jan 11, 2019 :
    is the beta only? I'm a OnePlus 5 user who is still on 5.1.7 and haven't received any 9.0.x releases, so I was curious if this was beta or a regular release. even on VPN I cannot get it to come up as an OTA update.
  11. Y1547127163469
    Y1547127163469 , Jan 11, 2019 :
    use Oxygen updater from store
  12. M1526418706179
    I connect a vpn to Hong-Kong Victoria to download it in OTA.
  13. F_Shon_Elliott_cbWP
    Donut Jan 11, 2019
    I'd rather not use anything unofficial which could cause problems. I do not have root on my device and do not wish to do so as it will break a lot of other things.
  14. G_Gaurav_Reddy_NHBd
  15. Runnry
    Eclair Jan 11, 2019
  16. G_Gaurav_Reddy_NHBd
  17. wrldtvlr
    Gingerbread Jan 11, 2019
    wrldtvlr , Jan 11, 2019 :
    Then VPN to a country where the update has been released or wait for it.
  18. F_Shon_Elliott_cbWP
    Donut Jan 11, 2019
    somebody reported it worked in India... so, I set my VPN to India and tried it again and it still didn't show up.i tried numerous other countries including Canada and nothing yet.
  19. wrldtvlr
    My experience has been not all VPNs terminate in a city where the OTA is available. I use NordVPN and had to try a couple of different German ports before it worked. You might also try Canada.
    F_Shon_Elliott_cbWP likes this.
  20. Tcat007
    It's the same zip you get with OTA. Seems it's the official OTA folks that are having the most issues.
