625
  1. sunilkumargoudkalli
    Froyo Jan 12, 2019
  2. R_Kiran_Prasad_2001
    Cupcake Jan 12, 2019
  3. R_Kiran_Prasad_2001
    Shamit_manohar likes this.
  4. Ashishbhai001
    Froyo Jan 12, 2019
    Ashishbhai001 , Jan 12, 2019 :
    can i flash it directly on latest open beta 22 via local upgrade to go back to stable channel?
    Thanks
  5. G_liam_angelus_nuXa
    Eclair Jan 12, 2019
  6. sunilkumargoudkalli
    Froyo Jan 12, 2019
    sunilkumargoudkalli , Jan 12, 2019 :
    bro go system update>go top right side settings logo clik it tap local upgraded
  7. G_Bharat_Prabhas_NjsN
    Gingerbread Jan 12, 2019
  8. M1509943752110
    Donut Jan 12, 2019
    M1509943752110 , Jan 12, 2019 :
    after recent update my mobile's back, recent and home buttons are not working, please suggest solution
  9. R_Kiran_Prasad_2001
    R_Kiran_Prasad_2001 , Jan 12, 2019 :
    that means it will go to the flash process or not
  10. jerry_007
    Froyo Jan 12, 2019
    jerry_007 , Jan 12, 2019 :
    When i double tap to open recent app on home screen it opens the app before the recently app i used.
    All this happening after pie updates.
    What to do?
  11. sunilkumargoudkalli
    Froyo Jan 12, 2019
  12. R_Kiran_Prasad_2001
  13. sunilkumargoudkalli
    Froyo Jan 12, 2019
  14. M1509943752110
    Donut Jan 12, 2019
    since I have updated oxygen OS 9.0.1, my mobiles back, home and recent buttons not working, please suggest solution
  15. R_Kiran_Prasad_2001
  16. sunilkumargoudkalli
    Froyo Jan 12, 2019
  17. vinay.habib
    vinay.habib , Jan 12, 2019 :
    OP 5T, after 9.0.2 issues reported:
    1. After restarting, the SIM preferences that I set for SMS defaults to SIM1 always.
    2. After restarting, the radio button colors change to pink.
    The same happened after 9.0.1. But there was a OnePlus launcher update that has solved the problem. Now waiting for the same to happen.
    Anyone having same issues?
  18. wizzent
    Eclair Jan 12, 2019
    wizzent , Jan 12, 2019 :
    Hello folks, after upgrading from 5.1.7 to 9.0.2 by TWRP following OP instructions of XDA relevant thread, I am running a smooth and stable system.
    Anyway I'm facing issue with Magisk as it seems that I have lost rootand there is nothing I can do to get that back working.
    I tried uninstalling and reinstalling Magisk through recovery witouth error messages but still I am unable to have root on my device.
    If I try to install through Magisk Manager I've got an "installation failed" message.
    This is going to make me crazy and as of today I didn't find any solution or workaround.
    Root has great value forward my phone daily usage habits.
    Is anyone here experiencing the same problem?
    Thanks
  19. Venkatesh Ainapur
    Froyo Jan 12, 2019
  20. Tommyd78
    Eclair Jan 12, 2019
    Tommyd78 , Jan 12, 2019 :
    Put your phone in a bag, shake it ,take phone out of bag and reboot you will have the update I was successful in doing that
    Mapeteusz likes this.
