625
  1. G_CriCkeT_007_mAAA
    Cupcake Jan 14, 2019
  2. rinku2bapi
    Gingerbread Jan 14, 2019
    rinku2bapi , Jan 14, 2019 :
    you tube app not opening after update to 9.0.1 . it open in chrome others app running normally with good internet connection.cleared cache and storage with restart but no change ...any solution
  3. paridhi123
    paridhi123 , Jan 14, 2019 :
    Still waiting for Android pie update...didn't think it would take so long...where is the update?? Anyone knows in which order update is rolled out in India...is it geographical or something..??
  4. C1513244171004
    C1513244171004 , Jan 14, 2019 :
    In Russia вполне себе официально продавался, так что и обнова будет вполне официально.
  5. ravichandrakn
    Donut Jan 14, 2019
    ravichandrakn , Jan 14, 2019 :
    Its been 13 days announced, i still not having updates. Not sure how many days i need to wait dor pie 9.0
  6. R1523999795049
    Donut Jan 14, 2019
    R1523999795049 , Jan 14, 2019 :
    I don't even know how to do it It is known that there is anybody here
  7. G_Tabrez_Basha_LZnp
    RamaKrishna1312 likes this.
  8. Ih.nihal
    Eclair Jan 14, 2019
  9. ktk89
    ktk89 , Jan 14, 2019 :
    Yes same here
  10. Ganeshbhavsar11
  11. Kamal Hans
    Ice Cream Sandwich Jan 14, 2019
    Kamal Hans , Jan 14, 2019 :
    Which update are you on?
  12. faqir.m.abdullah
    Froyo Jan 14, 2019
    faqir.m.abdullah , Jan 14, 2019 :
    After beta I clean flashed Oxygen OS 9.0.0.. however I didn't receive 9.0.1 update and I haven't received 9.0.2 either... what can be the problem? help?
  13. H1525611260602
  14. Kamal Hans
    Tcat007
    Agreed, Oreo is just as good. The only thing that actually looks different for my use is recents (which I do like better on Pie). Some substratum themes look better. But battery and everyday use is very similar. If I had half the issues on Pie that some of the folks here have, I'd be back on Oreo in a second. Just don't really understand the impatience here when they have a choice.​
    Plz keep in mind that a majority of owners now are not familiar with flashing roms side loading, rooting etc. They would just not know how to go back to Oreo.
    When my OP5 got bricked during the OTA installation process while updating from Oreo 8.1.0 to Pie 9.0, I had to hunt out someone who knew flashing etc. Others had to go to the OP service centre.
    For them, me included, an OTA is the only way. Or an app like Oxygen Updater.
    gorneanu likes this.
  15. G_Meher_Gupta_jdHX
  16. gorneanu
    gorneanu , Jan 14, 2019 :
    Wisdom and correct expectations. BTW, if OP has added any of the 3 version in the download section it means they are not ready to install...but then again...it's still their fault.
  17. G_Colin_Dodds_cIwC
  18. krish2690
    krish2690 , Jan 14, 2019 :
    when connected to Bluetooth headset, notification sound doesn't come in phone speaker. notification sound comes only with Bluetooth speaker.
  19. Suhas96
    Suhas96 , Jan 14, 2019 :
    It has been around 3 days and I still haven't received it yet. I have tried using the method of VPN as well and my phone is updated through OTA but to no avail. can you guys look into it ASAP otherwise thanks for your efforts on these fixes
  20. R1516296910940
