625
  1. Tejas Waghela
    Eclair Jan 2, 2019
    Tejas Waghela , Jan 2, 2019 :
    Canada or Germany sbould work.
  2. Tejas Waghela
    Eclair Jan 2, 2019
    By reading this forum. Thanks!
  3. vinorvmani
    Cupcake Jan 2, 2019
    vinorvmani , Jan 2, 2019 :
    use vpn to get update
  4. danishdaycare
    Ice Cream Sandwich Jan 2, 2019
    danishdaycare , Jan 2, 2019 :
    I always clear cache in recovery when something happens to my phone, know some who "knows the code" says it's of no use, but I still do it with good results. Also let your battery drop to 10ish % and charge it to 100 a few times so the battery cycles normal.
  5. snke
    Froyo Jan 2, 2019
    snke , Jan 2, 2019 :
    for me VPN method doesn't work
  6. Tejas Waghela
    Eclair Jan 2, 2019
  7. Sid_Ck
    Sid_Ck , Jan 2, 2019 :
    It takes a few seconds as it tries to load before getting errors saying that cannot retrieve messages or connection error
  8. snke
    Froyo Jan 2, 2019
    can install on star wars edition?
  9. sachkharb
    sachkharb , Jan 2, 2019 :
    If 3 and 3T gonna get P then 5 and 5T may be possible
  10. Abhishek Garlyal
    Cupcake Jan 2, 2019
  11. JanPaulC
    Cupcake Jan 2, 2019
  12. PokiX
    Jelly Bean Jan 2, 2019
    PokiX , Jan 2, 2019 :
    Feature
  13. swaraj_c.r.
    Gingerbread Jan 2, 2019
  14. Razvan B.
    Razvan B. , Jan 2, 2019 :
    gorneanu
    Salut Razvan,
    Sunt constient ca ajunge dar sunt sigur ca nu suntem prioritate in acest "incremental roll-out". Prin VPN nu vreau. Cred ca sunt si probleme de distributie datorita faptului ca toata lumea baga VPN. Desi poate OP isi doreste sa ajunga initial la 10% din utilizatori, prin VPN se duce la 80% si pe urma apar multe posturi cu probleme...si uite asa se apuca de un nou beta...etc. Cred ca intelegi ce vreau sa zic. La multi ani!​
    La multi ani frate român!
    Ai rabdare atunci inca o luna cel putin, din ce citesc eu aici in fiecare zi sunt probleme multe cu 9.0 si 9.1. Asteapta inca o luna sa se planga astia ce l-au instalat deja iar apoi sa speram ca o sa repare buguri-le. E bine sa astepti si sa ii lasi pe altii sa fie soareci de laborator. nu cred ca vrei sa ai probleme si sa te enervezi ca nu iti merge aia si aia dupa update. Eu o sa mai astept o luna sa le verifice si repare. telefonul functioneaza perfect nu am nevoie de placinta asta sa imi dea dureri de cap si stomac
    gorneanu likes this.
  15. rinku2bapi
    rinku2bapi , Jan 2, 2019 :
    may be solved after restart ..or sometimes it correct automatically...
  16. swaraj_c.r.
    swaraj_c.r. , Jan 2, 2019 :
    ty
    rinku2bapi likes this.
  17. swaraj_c.r.
    I even tried restarting but it didn't work.what to do
  18. rinku2bapi
    some problems occur after major updates...contact higher authority...
  19. swaraj_c.r.
    how can I contact them
  20. rinku2bapi
    C1522817504370
    see this post...see manu j....on top ..press on this...and message
