624
  1. farazk3
    Gingerbread Jan 23, 2019
    farazk3 , Jan 23, 2019 :
    Screen cast is still broken doesn't work for me on op5 even after 9.0.3 update any workaround for this.
  2. Cervantes
    Lollipop Moderator Jan 23, 2019
    Cervantes , Jan 23, 2019 :
    Hi
    The update thread is a thread of questions and/or commentary
    Please, read the first post
    https://forums.oneplus.com/threads/oxygenos-9-0-2-hot-fix-ota-for-oneplus-5-and-oneplus-5t.975880/
    Thread merged
  3. Sargo
    Ice Cream Sandwich Jan 23, 2019
    Sargo , Jan 23, 2019 :
    wait
    you probably wont receive it as the newest is 9.0.3 and you will get that instead
  4. S1520124702248
    Froyo Jan 23, 2019
    S1520124702248 , Jan 23, 2019 :
    what about the screen shot...and you are living on the top of the cliff
  5. Tcat007
    Honeycomb Jan 23, 2019
  6. Wolfman007
    Eclair Jan 23, 2019
    Wolfman007 , Jan 23, 2019 :
    Everything is working correctly then.
  7. sasindradev
    Cupcake Jan 23, 2019
    sasindradev , Jan 23, 2019 :
    after doing the beta update my phone gets frozen at times n also some times I get a blank screen ? anyone else is facing the same issues? is there any rectifications?
  8. Cervantes
  9. Ranjane Ashwin
  10. morikee
    Eclair Jan 23, 2019
    morikee , Jan 23, 2019 :
    what problem
  11. Ranjane Ashwin
    Ranjane Ashwin , Jan 23, 2019 :
    app closing as you scroll through different app. previous app gets closed
  12. Cervantes
    Hi
    Thread merged
  13. Asif_hussain
    Froyo Jan 23, 2019
  14. lost_signal
    Donut Jan 23, 2019
    lost_signal , Jan 23, 2019 :
    This is also my experience. As far as I can tell, the August and October updates (which successfully worked for me, too) were stable releases. I never, ever go for Beta releases as a matter of personal course.
    Unfortunately, it seems OP had issues with 9.0.0, 9.0.2 releases -which would be my guess for the reason that neither appeared in the stable release tab for the 5T. For some users, 9.0.3 (which was recently released) is useable. For me, it is not. I rooted my 5T from day one. I've attempted to direct flash the update (OTA), attempted to download then "local update", and have tried flashing it via TWRP (TeamWin Recovery Program. One all three of those attempts, I received a "Zip Treble Incompatibility error" when attempting to update to 9.0.3 via TWRP this morning.
    From my perspective, there's a lot of confusion as to whether or not TWRP is Treble compatible. Over the course of my searches (a few results were from Reddit), TWRP IS Project Treble compatible; others state that it is not. Many suggest removing compatibility.zip, but I'm not planning on taking that route.
    The entire process of updating is frustrating. It's even more frustrating when OP itself isn't at least providing the OS update on the 5T download page (https://www.oneplus.com/support/softwareupgrade/details?code=7) -which, as you'll note, still has the Nov 2018 patch.
    Even more egregious, is OP's lack of communication. It doesn't state (not in any responsible or clear way) whether or not hot fixes, such as 9.0.2 or 9.0.3 include the slated updates and fixes originally slated for the 9.0.0 (Dec 2018) release, which include:
    9.0.0 Update Notes
    - update system to Android 9.0 Pie
    - brand new UI for Android Pie
    - brand new navigation gestures
    - updated Android security patch to 2018.12
    etc.
    9.0.2 Update Notes: [I'm missing this info, but discovered that there was some sort of display-related bug]
    9.0.3 Update Notes:
    Hot Fix:
    - fixed connectivity issues with certain third party apps [whatever that's supposed to mean]
    - improved stability for sound settings
    - stability improvements for system upgrade [HA! good one!]
    System:
    - Optimized sRGB display mode
    - Optimized Reading mode [Whoopie]
    - Fixed issue with 4G VoLTE toggle missing
    - Fixed random reboots when screen casting
    It's all incredibly confusing and frustrating.
    Meanwhile, I'm looking into my TWRP-Treble issue some more. It's simply unacceptable that, in 2019, users still have to wait for security upgrades.
  15. S1520124702248
    Froyo Jan 23, 2019
    phone is getting over heated, screen shot sound is there (which should not be there in vibration mode).
    if these are not the problem then my phone is working fine.
    I will recommend not to update...OnePlus is just making a fun of us by providing so many problems...wish they could have tested it before in their own environment before releasing it to mass.
  16. BiswajitB
    BiswajitB , Jan 23, 2019 :
    I was on 9.0.2. Try downloading using Oxygen Updater
    Divyanshu_Agrawal likes this.
  17. AndroFan
  18. Divyanshu_Agrawal
    Froyo Jan 23, 2019
    Divyanshu_Agrawal , Jan 23, 2019 :
    i am in no hurry, i will wait for a bit more polished pie, till then i enjoy oreo.... i just wanted to know in general... thanks btw...
    rmjb likes this.
  19. N1524300102050
    Donut Jan 23, 2019
    N1524300102050 , Jan 23, 2019 :
    there is still animation lag when you close or open apps
    Incognito icon doesn't disappear when you close em in notification menu
  20. Hitman10
    Hitman10 , Jan 23, 2019 :
    I think it may resolve itself.i had same issue in past then it started working
