625
  1. rushup
    Froyo Jan 23, 2019
  2. Aziz_Amin_Oneplus
    Jelly Bean Jan 23, 2019
    Aziz_Amin_Oneplus , Jan 23, 2019 :
    Last stats for my battery life on Oxygen OS 9.0.2 is like this;
  3. Sahil Naik
    Gingerbread Jan 23, 2019
    Sahil Naik , Jan 23, 2019 :
    Everything's fine for me
  4. H1548240846556
    Eclair Jan 23, 2019
  5. shiva_jadhav
    Eclair Jan 23, 2019
    shiva_jadhav , Jan 23, 2019 :
    will i also get pie with this update? bcoz I'm getting this update after 5.1.7. so will it change from oreo to pie?
  6. Aziz_Amin_Oneplus
    just follow my above steps are you will be good to go and wipe cache from recovery also that is important when you update your software.
  7. H1548240846556
    Eclair Jan 23, 2019
    H1548240846556 , Jan 23, 2019 :
    which step bro
  8. 5384vishal
    Cupcake Jan 23, 2019
  9. H1548240846556
    Eclair Jan 23, 2019
    my software is also updated
  10. MarkyPancake
    Honeycomb Jan 23, 2019
    MarkyPancake , Jan 23, 2019 :
    Checked for an update today on my UK OP5 and nothing, so used a Canada VPN and the 9.0.3 update was available, same as 9.0.0 a few weeks ago. Installed it and no issues so far, but I never had any issues on 9.0.0 either.
  11. vamshiamvt
    vamshiamvt , Jan 23, 2019 :
    putting on invert colours my screens flashing flickering , it's like my phone's getting confused
  12. Aziz_Amin_Oneplus
    See my post 8626 and follow the steps and be sure to wipe cache from recovery mode.
  13. H1548240846556
    Eclair Jan 23, 2019
    i after update wipr my cache
  14. H1548240846556
    Eclair Jan 23, 2019
    4 to 5 circle means
  15. sachkharb
    Ice Cream Sandwich Jan 23, 2019
  16. Aziz_Amin_Oneplus
    Yes it needs at least 4 to 5 cycles for making the battery understand about the apps and the system.
  17. Aziz_Amin_Oneplus
    The check the beta, there you will get something fresh bro.
  18. Q1545504703112
    Q1545504703112 , Jan 23, 2019 :
    Hey, do you know if 9.0.3 fixes the lag and stutter issue?
  19. X1545793414457
  20. sundar3193
    Eclair Jan 23, 2019
