625
  1. Q1545504703112
    Honeycomb Jan 23, 2019
    Major Rager likes this.
  2. Aziz_Amin_Oneplus
    Jelly Bean Jan 23, 2019
    Aziz_Amin_Oneplus , Jan 23, 2019 :
    It will remain i think till Android Pie reach the middle of it, like 5.1.4 Oreo update ssssshhhhh still missing it :(
  3. vsfabio4
    Cupcake Jan 23, 2019
    vsfabio4 , Jan 23, 2019 :
    can I downgrade? feels less snappy and generally more laggish than what I was used to
  4. Aziz_Amin_Oneplus
    Your wish, what you feel, i would say you will miss the New UI, New Gestures, Latest Security Update and New features.
  5. vsfabio4
    A'ight, I'll try to be useful to the community and tell what I noticed (in my first couple of hours of use) that doesn't quite work as well as before:
    -first:
    the swipe down animation of the notification center is soooo much slower now/ so much so I had to turn on the developer options to accelerate animations (and trust me, it doesn't deliver that premium sensation I had before using this phone)
    -second:
    the Ambient display act as my night mode is turned off even when it's not
    -third:
    once every while, when I press the home button it opens the multitasking tab instead
    I appreciate so much your interest in users' opinions, won't downgrade for a while to help fixing this, if it'll work.
    thanks
  6. cubanorafter
    Froyo Jan 23, 2019
    cubanorafter , Jan 23, 2019 :
    Cool, I didn't notice that. Will have to try that out...
    Just got the update this morning OTA and everything still running silky smooth (OP5)
    Battery seems the same as 9.0, 9.0.1, and 9.0.2..
  7. F_Charan_Goppireddy_SVwb
    F_Charan_Goppireddy_SVwb , Jan 23, 2019 :
    Bullet c type earphones are not working for one plus 5t... Can you plz slove the problem plz...
  8. Selby33
    Froyo Jan 23, 2019
    Selby33 , Jan 23, 2019 :
    After upgrading from 8.1.0 to 9.0.3 I can not download from google play... Help pls
    angel_dope likes this.
  9. angel_dope
    Gingerbread Jan 23, 2019
    angel_dope , Jan 23, 2019 :
    Hi there, just upgraded to this latest version and found a little problem.
    I've tried to update apps from the play store but they won't download. They keep as downloading but don't download a single bit. The same if I try to install a new app.
    If I power off the phone and power on again, I can install one app, but after that, of you try to update or install an app, it does the same again
    Selby33 likes this.
  10. angel_dope
    Just after posting this, suddenly the apps which were sticker in download.... are downloaded and installed. I'll keep an eye on this
    Selby33 likes this.
  11. M1540104160148
    M1540104160148 , Jan 23, 2019 :
    can you please bring back the battery percentage on the bottom of the lock screen while charging? it's gone since the upgrade to Android P and I really miss it. now I need to unlock the phone and pull down the drawer to check the battery percentage.
  12. Selby33
    Froyo Jan 23, 2019
    Yes, and me too. But I had this already and then again stopped loading from google play.
  13. Tcat007
    Tcat007 , Jan 23, 2019 :
    It's under the clock.
    doekus likes this.
  14. M1540104160148
    doekus likes this.
  15. angel_dope
    After that I've tried to install another app, but there was no way. I've rebooted the phone one more time, and more I've been able to install five apps without any problem.
    I'll do some more tries the next few days.
  16. Selby33
    Froyo Jan 23, 2019
    angel_dope
    It seems to understand what's the matter. Turning on bluetooth again activates this problem.
    Although it seems to work again. Maybe this is not the problem...
  17. KRZYSZTOF_BEDZISZ_BEDA
    Eclair Jan 23, 2019
    KRZYSZTOF_BEDZISZ_BEDA , Jan 23, 2019 :
    install 9.0.3 and enjoy...
  18. sandy48
    H1516463162704 likes this.
  19. dziarsky
    janez33 likes this.
  20. janez33
    Eclair Jan 23, 2019
