625
  1. PokiX
    Jelly Bean Jan 24, 2019
    PokiX , Jan 24, 2019 :
    Good! Have fun (I hope)
    dareknowak likes this.
  2. Chirostavros
    Gingerbread Jan 24, 2019
    Chirostavros , Jan 24, 2019 :
    hi everyone, today I had an notification to update my 5t to 9.0.3. OTA. I currently run 5.1.4. Is it safe to proceed to the update?
  3. jmarks
    Honeycomb Jan 24, 2019
    jmarks , Jan 24, 2019 :
    @ruijmeira, obrigado pela resposta.
    Estava a pensar em fazer uma instalação limpa mas isso fá um pouco de trabalho e agora não tenho tempo.
    Vou tentar fazer como tu.
    Abraço.
  4. ruijmeira
    ruijmeira , Jan 24, 2019 :
    De nada.
    Pois, eu fiz um backup só para o caso de vir a precisar de uma instalação limpa, isto porque queria primeiro experimentar esta forma mais preguiçosa eheh.
    Abraço
  5. bogdan.soare9
    Froyo Jan 24, 2019
    bogdan.soare9 , Jan 24, 2019 :
    Chirostavros
    hi everyone, today I had an notification to update my 5t to 9.0.3. OTA. I currently run 5.1.4. Is it safe to proceed to the update?​
    That's odd. I don't think you should. You need the 5.1.7 update with Treble support before you upgrade to Pie but I might be mistaken since OP sent you the update...
  6. Ray_ofLight
    KitKat Jan 24, 2019
    Ray_ofLight , Jan 24, 2019 :
    Very well received the Oxygen OS 9.0.3.. Updated from 9.0.2. Thanks OnePlus for the fast updates.
  7. Vitor Valeri
    Eclair Jan 24, 2019
    Vitor Valeri , Jan 24, 2019 :
    I found the notification icons very small at the top of the screen. See the size of the number that tells the temperature at the moment (comparing the time numbers). The application in question that tells the temperature is the AccuWheater.
  8. Jaccob
    Cupcake Jan 24, 2019
    Jaccob , Jan 24, 2019 :
    Hey thank you very much for this update! I was going from the Oreo straight to 9.0.3 and it's absolutely awesome!
    Much more fluent, good battery life and nice recent apps layout.
    One downside is position of clock but I will be able to adapt.
    I am really happy that I can use Digital Wellbeing app.
    No issues yet. So we will see.
  9. domestoboto
    domestoboto , Jan 24, 2019 :
    Why are you SO WORRIED about people being able to know that you're taking a picture of them without consent?
    PA579 likes this.
  10. jujudelgado
    Eclair Jan 24, 2019
    jujudelgado , Jan 24, 2019 :
    Updated as well, from Italy. Really nice update, everything works flawlessly. Some small lags mostly on play store but nothing apocalyptic. Well done One Plus!
  11. L1540416052587
  12. L1540416052587
  13. PokiX
    It could be the purpose of the compatibility.zip which is included in any ROM zip from OOS.
    You could ask confirmation with having a chat with support although OP never made any requirements on previous versions so I'd say... GO!
    In any case, make sure your user data are properly backed up!
    You'll always be able to recover.
  14. PokiX
  15. L1540416052587
  16. L1540416052587
    L1540416052587 , Jan 24, 2019 :
    you got this update
  17. PokiX
    No, I'm using beta testing branch.
    If you have question, feel free to ask ;)
  18. Abdelaziz_Aqel
    Abdelaziz_Aqel , Jan 24, 2019 :
    Bluetooth still to figure correct device
    like
    camera pairing as printer
    WiFi direct loss connection fast and not connected all time
  19. Shidharth Jayakannan
    Shidharth Jayakannan , Jan 24, 2019 :
    Jaccob
    after install how to find it? digital wellbeing
  20. Atorpat
    Atorpat , Jan 24, 2019 :
    I can no longer see my 2.4GHz wireless and only see the 5G one after upgrade to Pie.
    Has anyone else encountered the same problem?
