625
  1. G1511430137630
    Donut Jan 25, 2019
    G1511430137630 , Jan 25, 2019 :
    Thank you, I understand now. Yes I'm in one of those countries. But, I assume this is a bug which will be addressed by the OnePlus team.
  2. Rohan.M
    Gingerbread Jan 25, 2019
    Rohan.M , Jan 25, 2019 :
    One plus has become lagplus now, UI is so much lagging at times that I feel I am using an old Samsung phone with its lagging TouchWiz UI, #feelthelag should be a new tag line for OnePlus...
  3. firedeamonxen
    Eclair Jan 25, 2019
    firedeamonxen , Jan 25, 2019 :
    That is why I wrote Issue/Bug/Feature...as this has been to the user in these geo location I would say it's a feature introduced from 9.x.
  4. Anthony210281
    Cupcake Jan 25, 2019
    Anthony210281 , Jan 25, 2019 :
    fully agree! just starting to notice this now. #feelthelag
    Major Rager likes this.
  5. Mitz Parmar
    Mitz Parmar , Jan 25, 2019 :
    Had the push last night but haven't upgraded until this morning as I wanted clarification that a game that I was playing is compatible.
    Now I've upgraded lets get through the nooks and crannies.
    I'm in the UK so hopefully others have or are getting the push steadily now
  6. firedeamonxen
    Eclair Jan 25, 2019
    Yea by the looks of the recent comments by the community...it seems they have rolled it out globally...
  7. G1511430137630
    Donut Jan 25, 2019
    Hmm... If not sure if it's a feature because, if it was a feature there would not have been an option to enable/disable and disable the camera sound.
    Here we have that feature but, it's not working. Request the OnePlus team to look into and sort out this issue.
  8. Tolerant Feminist
    Tolerant Feminist , Jan 25, 2019 :
    HUGE PROBLEM WITH THE UPDATE!
    Let me explain.
    Got the update yesterday for the device: OnePlus 5. (update 9.0.3)
    Everything was working great pre update (I didn't receive 9.0.2 nor 9.0.1 update beforehand)
    -I updated from 8.1 to 9.0.3 and the phone started ignoring my touch (screen not reacting to my touch).
    -12h after the update it still is not responsive to my touch. I tried hard resetting, did not work.
    -I went to recovery but to enter recovery mode I need to enter my password, I cannot do that hence the phone screen doesn't react to my touch.
    -This is the first time it happened and I have literally no way of getting to my files.
    -Phone is not rooted, under warranty, 8 months old. Bought from local provider. 1st hand user.
    Is there a way of fixing this?
    Thank you, cheers.
  9. S1514478214868
    S1514478214868 , Jan 25, 2019 :
    wonder what everyone is cribbing about..I updated and found the phone to work just fine and smooth...
    battery life is good
    selfie has beauty mode and portrait mode
    theme options r good
    layout change is fine but not trendy
    Animation is not lagging
    the only con is they removed cache clearance from setting.. (but I guess it's not that important)
    5t feels new again... ofcourse I did a factory reset. always recommended.
  10. vincent.manjuran
    vincent.manjuran , Jan 25, 2019 :
    yes, you need to flash via fastboot. I wouldn't recommend doing it by yourself though. contact support, they'll flash it for you via remote access. [e]1f44d[/e]
  11. Tolerant Feminist
  12. vincent.manjuran
    Live chat should suffice. they'll guide you through the steps. will give you a link to download a password protected file to which they have the key.
  13. mohitnagpure
    mohitnagpure , Jan 25, 2019 :
    after update getting this.. what is the Frist volume bar indicate before media volume bar?
    anyone know ?
    TIA.
  14. Tolerant Feminist
    I will try doing that as soon as they open live chat. Will come back after it is done. Thank you.
  15. T1511255580548
    Donut Jan 25, 2019
    T1511255580548 , Jan 25, 2019 :
    on android Oreo it was possible to activate split screen and now I can not start split screen in Android pie. anybody know how to activatie split screen in Android p?
  16. vincent.manjuran
    Yeah! you're welcome. they might ask you to send in the device to the service centre. So you'll have to request them to flash it via remote access. [e]1f44d[/e]
  17. vincent.manjuran
    On the multi tasking screen, tap on 3 dot to access the menu to get into split screen mode of the compatible app.
    T1511255580548 likes this.
  18. Tolerant Feminist
    I will request flash via remote access then. Thank you.
  19. vincent.manjuran
  20. T1511255580548
    Donut Jan 25, 2019
    thanks![e]1f44d[/e]
